Oil temperature switch/sensor
Old May 11, 2006 | 07:01 PM
85 Z-51's Avatar
85 Z-51
Default Oil temperature switch/sensor
Does anyone have any info on the oil temp switch/sensor, no one seems to list it locally. Is there a number i could cross reference?
If anybody could shed some light, it would be appreciated.
Old May 11, 2006 | 08:34 PM
CFI-EFI's Avatar
CFI-EFI
First you have to decide that you are looking for. There is an oil pressure SWITCH that is wired into the fuel pump power supply. And the is an oil temperature SENDER that supplies input for the oil temp gauge. Neither of these, of course, should be confused with the oil pressure sender. In summery, for oil pressure, there are both a sender and a switch. For oil temperature, only a sender.
RACE ON!!!
Old May 11, 2006 | 08:53 PM
85 Z-51's Avatar
85 Z-51
Default temperature
temperature is what i'm looking for
i've seen it listed as a switch and sensor, but definately temp
Old May 12, 2006 | 12:49 AM
froggy47's Avatar
froggy47
Me too, sender, mine's off about 8 degrees. Where is the bugger?
Old May 12, 2006 | 05:54 AM
86PACER's Avatar
86PACER
It threads right above the oil filter on L98's. Not cheap though.
http://www.artscorvetteparts.com/par...9-cd81cf9014d3
Old May 12, 2006 | 06:37 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Pick it up at NAPA!!!! about $30
Old May 12, 2006 | 10:48 AM
85 Z-51's Avatar
85 Z-51
Default Always low
My oil temp guage has read low since i bought the car last year. I don't know if it makes a difference or not, but I thougt I'd change it while I have the exhaust off and there is more room up in there.
Old May 12, 2006 | 10:56 AM
85 Z-51's Avatar
85 Z-51
Default no go at napa
Napa said they don't carry it, but I did get their part number. Could anyone cross ref this number to another brand. OTS201 eglin part?
Old May 12, 2006 | 12:14 PM
froggy47's Avatar
froggy47
Is it located the same on the LT4 engine? Above oil filter?
Old May 12, 2006 | 02:53 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yup. Should be to the right side of the filter.
Old May 12, 2006 | 04:16 PM
froggy47's Avatar
froggy47
Thanks.
Old May 13, 2006 | 01:35 PM
CFI-EFI's Avatar
CFI-EFI
I didn't cross your part number, but I did look it up for you in my GM, Corvette parts book. The GM part number for the oil temperature sensor is 25036292. It fits 1984 through, at least, 1989, as late as my book goes.
RACE ON!!!
Old May 22, 2006 | 04:58 PM
85 Z-51's Avatar
85 Z-51
I found one at a car quest dealer part #72-4659, listed as a temp switch. It's installed now and the vette's back on the road again, , but my temp guage still reads low all the time, . Checked the wire for as far as I could follow it, looked good. Is this something I should be concerned about? Any ideas would be appreciated.
To Oil temperature switch/sensor
