Transmission Swap Question
Bernie
-- Joe
Figure for the master, slave, spacer, clutch line and pedals $ 550 Don't forget a heat shield for the slave.
for the transmission and a bellhousing, fork, pivot $ 12-1500
for the yoke $75
for the clutch, pressure plate, flywheel, etc. $ 800-1200
for the console pieces, unless you modify yours $ 100
for SMC tunnel mods $50
$2775 - $3475
you can save some funds by using the stock clutch, pp, flywheel,
used parts, but why? -$500-900
And of course, there's the Dana 44, that Dana 36 with 2.59-2.73-3.07s is going to be hell on the clutch and the pocket book when it breaks. You can cryo and gear it for $600 or so, less if you can gear it yourself.
Now, the interesting part, it's a 91 convertible, late style body, L98.
johnny
for the yoke $75
$2775 - $3475
johnny
Is their a better site for this type of technical info? I've searched posts
and can't find as much as I'd thought i'd find.
How do 4+3 bell housings differ from the ZF ? maybe I need both a '91 and '87 helms manuals.
Dana 36 gears seem kinda cheap in the summit catalogue. I can't imagine they're much harder to setup than a 10 bolt. ?? I know they're suposedly weaker due to the 7.5" ring gear (like a fbody 10 bolt), wonder if the same things make 'em stronger (girdle, cap supports, etc). ?
-- Joe
for the yoke $75
$2775 - $3475
johnny
But if you have to pay someone you can add $200 to $300.
I'm probably gonna run the 700R4 for a while until it blows up, with just a converter and a shift kit, but i'd like to get the pedals and hydraulics in while the motor is out.
-- Joe
