are you asking what the engine has or what I want to buy ?
Whats in the car now is the 1989 L98 that came from the factory
Is it going to be a L98 crate motor? Or a 383 long block plus a miniram? Depending on price, using a ZZ4 crate and pulling the carb manifold may be the best route.
I vote for the L98 to avoid the complications of tuning problems. After all the object is to get track time, not shop time. The 383 miniram can wait until Lilred has outgrown the L98 power.
I agree. not sure what she wants to do. In the end its up to how much $$ she wants to spend.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by Bluewasp
I performed a leak down test on the problem child L98 here are the results.
88k miles, COLD engine...
Numbers would be higher (better) if the test was done on a warm engine..
Why did you run a leakdown (differential compression) test on a cold engine? What was the base pressure? How did you control piston location during the test?
On piston aircraft engines, a delta comp test is standard procedure. The test is always run on a warm/hot engine or otherwise the test is considered invalid. The prop is used to control the piston location and the pressure can be misrepresented if the rings are not in the bottom of the grooves. 80 psi is the standard base pressure and monitored as each cylinder is tested. An 80/75-70 is an average good test pressure. Less than 80/70 is reason to watch closer depending upon total time, aka miles.
Maybe it would be best to run a standard compression test. And then if these results are low, run a delta test.
What is your definition of a "warm engine". 100 ? 200 ? 150? I drove the car into the garage and let it cool down so I didn't burn myself. . I'm not about to pull the plug(s) on an engine at 220 degrees.
I didn't say ICE cold, left over night... I went back a read my first post in this thread and can see how you interpreted my use of the words “cold” and “warm”. I should have said cold enough to touch without getting burned.
I didn't run a "Standard compression test" because I wanted to see where pressure is escaping. A compression test wouldn't tell me that. ie past the rings, the intake valve, or the exhaust valve.
In any case the issue here is the variation between cylinders 10-12% and 32% which is a big difference.
