window switch
Old May 14, 2006 | 02:46 PM
c4 4 me's Avatar
c4 4 me
Default window switch
If you run a window switch do you not use the WOT switch?
Old May 14, 2006 | 07:51 PM
Legion21's Avatar
Legion21
A window switch is run with a WOT. The WOT throttle switch closes the circuit, and the window switch will provide the ground when the pre-set rpm is achieved. They basically set 2 parameters that need to be met for the nitrous to activate.
Greg
Old May 14, 2006 | 09:20 PM
c4 4 me's Avatar
c4 4 me
Greg, so when the WOT switch is activated at full throttle, nitrous won't spray until a pre-determined RPM is reached? Then is the window switch hooked to the same terminal on the solenoid as the WOT switch, or between the WOT switch and solenoid?
Old May 15, 2006 | 11:48 AM
neat's Avatar
neat
There's a couple ways you could wire it.
I would wire it in series so that the WOT switch only see's 12 Volts when the window switch is between your set RPM's. Then, when you go WOT, the WOT switch allows that 12V to go to a relay that opens the solenoid, or as you are describing, to solenoid itself. Hang on, and I'll MS paint you a wiring diagram.
Old May 15, 2006 | 12:05 PM
94vette1's Avatar
94vette1
yes
on my msd it switches to ground so depending on your hook up it can go on your noid ground our relay ground or wot switch ground
good luck
Old May 15, 2006 | 12:46 PM
neat's Avatar
neat
Here's the way I would wire it:
Old May 15, 2006 | 12:48 PM
neat's Avatar
neat
And here's what I think you are describing, with no relay:
Old May 15, 2006 | 12:52 PM
neat's Avatar
neat
Yet another way you could wire it with no relay:
Old May 15, 2006 | 02:00 PM
neat's Avatar
neat
And yet another way, using a relay in the ground circuit this time:
Old May 16, 2006 | 12:57 PM
c4 4 me's Avatar
c4 4 me
Thanks neat that will help.
To window switch
