Back latch
Old May 15, 2006 | 07:59 AM
DonF's Avatar
DonF
Default Back latch
On an 89 how do you get the back hatch to open manual? I can here a click coming from the back but it won't release. Thanks Donf
Old May 15, 2006 | 08:11 AM
JoBy's Avatar
JoBy
There should be a short wire you can pull to release it manually. Feel around near the lock at the rear.
Old May 15, 2006 | 08:33 AM
DonF's Avatar
DonF
The wire in my Z06 is in plain sight, could it be under the carpet on a 89? I crawled back there & looked there isn't a wire visible. Thanks
Old May 15, 2006 | 08:40 AM
todd_vette87
Guest
Posts: n/a
Feel around under the carpet and under the back side of the shade roll. It should be just to the pasenger side of center coming from the release latch. It is kinda hidden. Reach under the shade just to the back of it.
Good luck.
Old May 15, 2006 | 08:54 AM
DonF's Avatar
DonF
THanks, I'll try again when I get home Donf
Old May 15, 2006 | 10:44 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yeah what he said. It takes some force to pull that cable.
I popped the hatch on your vette with a mini vise-grips a few weeks ago. Ron said that was the first time it had been opened. I recall the struts being in good shape though.
Check for a cable below/behind the cargo shade towards the passenger side.
Old May 15, 2006 | 11:14 AM
DonF's Avatar
DonF
Yea, lots of work so far but almost ready to autocross this coming wk. end. I bought another set of rims for some sticky tires, but will run Group 1/S until I can arrange things. This sale worked out real smooth w/Ron I'm sure he will say the same. Thanks, Donf
Old May 15, 2006 | 11:24 AM
tequilaboy's Avatar
tequilaboy
Is the glass just sticking to the weatherstipping? If so, Open the gas door and you can pull up on the glass at the rear to open.
Old May 15, 2006 | 11:37 AM
DonF's Avatar
DonF
No, I tried that the latch isn't releasing. Thanks
Old May 26, 2006 | 01:24 AM
cv67's Avatar
cv67
St. Jude Donor '05
Its under there, Don. Its a biatch to get to, but it does release. Ive only had it open once since I owned it.
To Back latch
