Getting ready for my super Hotcam install...im sure it will be fun . I need to know a few things...
Do any of you know alot the of the torque specs?
Do I need a special tool to pull the harmonic balancer?
Is there a certain special order to adjust the valves or is it just standard GM Small Block 350? Run across some that have been different for some reason.
The stock LT4 rocker arms are non-adjusting, just torque to spec.
