I recently purchased a used LT1 block to build as the bottom end for my project. Its a 2 bolt block, so I'm having splayed 4 bolt main caps installed. I've seen different kinds ranging from $90 (Eagle) to over $200 (Milodon). Why such a disparity in price? Are the milodon parts that much better?
Also investigating rotating assemblies. Some folks seem to have an aversion to Eagle rotating assemblies. What is everyone's experience here? I'm looking for the range of 650 RWHP. The big advantage I see to the Eagle kit is that its available already balanced. There do not seem to be a lot of good machine shops in this area, so getting a kit that is already balanced is a requirement. By the way, I'm building a 383.
perhaps Eagle parts are made in China; Milodon parts are made in the USA? just a guess...
Well the Milodon caps are listed as ductile iron and the Eagle parts as billet steel, so its not a valid comparison to say that the country of origin is the main source of the difference.
I suppose I should have asked the question this way: What material is the best for the 4 bolt main caps on my application?
Actually the origin of the Iron has alot to do with the strength of the part. If they are using Chinese steel it will not be as strong as if it used American steel. That being considered the country of origin does make a difference.
Original Purpose of thread: Help from someone with experience with different rotating assemblies and main cap material types.
Responses: Steel from other countries is cheap and sucks!
I purchased a forged Eagle 383 rotating assembly last week. Still haven't purchased main caps as I'm having trouble getting the front and rear caps for the spare block I bought. If it doesn't work out, I'm just going to tear down the original LT4 and use it.
We used the eagle splayed caps and they held under a 800 hp motor. Make sure you get the ones that are on a 22 degree angle. And I don’t know if you added it the cost up yet but plan on spending 800$. You have to line bore and line hone the block pulse the cost of the conversion. That’s not including the cost of boring and honing the cylinders … but its worth the money
Yeah, so far the machine shop bill is up to about $1200 including the main caps. I didn't know Eagle had 22 degree caps. I thought they were all 18 degree caps? I just checked the catalog and could not find the 22 degree ones. I have noticed that some other manufacturer's are at different angles.
I use Pro-gram in my own car. I also am fond of Callies mains. Made here in the USA by your friends and Neighbors.
Top quality machining from top quality (I bet you can get the material certs if you asked) material. worth the money in my mind ( they only hold the CRANK in)!!!
