I had a 15 Lb FW and we/Ol'RJ could not tune out a slight studder that would oocur at the same RPM, every time when slowly going up thru the RPM range..
I put the heavier 30 lb FW in and the studder went away, we found this out accidentallyy, but realized it after the studder went away.
One thing that helps SM gear rattle is raising your idle rpm if possible. It gets better with a higher idle around 900+ rpm. Also... for some reason, the dual discs don't seem to have the gear rattle the single discs have.
Very happy with the SM Camaro Flywheel and Mcleod stage 4 ( Bronze Pucks) clutch in my 396 LT1. Been driving on the street and to the track for six years with this set up. The Camaro flywheel weighs 22 LBS so its about 18 LBS less than the DM. It is cast steel. When balanced properly it is not much louder than the DM in normal driving. Yes, it is noisy with the clutch out in neutral. Setting my idle at 1000 RPM's did minimize the noise.
With the Power Effects exhaust open, headers and off road pipes on, the SM flywheel noise is not even an issue.
