Compressing rear brake piston???
Old Aug 24, 2001 | 03:04 PM
Onyx's Avatar
Onyx
Default Compressing rear brake piston???
hey guys, I'm doing the rear brake pads today. They're pretty worn (probably the OE pads). I was just wondering if there is any trick to getting the piston compressed to make room for the new pads. I popped the cap on the cylinder, but i've given it all i've got and can't get the piston to budge. It needs to go in quite a ways before there is room for the new pads and I'm just not getting it to move. I did see there was a hex type bolt in the center of the piston do I need one of those special tools to compress it? Any help would be greatly appreciated. I'd probably be done by now, but I've already sent my service manual up to my new place in WA.
thanks.
Old Aug 24, 2001 | 03:22 PM
KDuniverse's Avatar
KDuniverse
Default Re: Compressing rear brake piston??? (Onyx)
open the master cylinder
Old Aug 24, 2001 | 03:26 PM
Nathan Plemons's Avatar
Nathan Plemons
I just used a bar clamp. It works great on the back, the front is the same way, but you need two clamps as it's a dual piston design.
With a little force from the clamp it will move quite easily, can't make it budge by hand. I even used one of the hand squeeze style, worked great.
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
A C-clamp works if you have the cap off the master cylinder.
All the cars I've ever worked on with disk brakes had to use that, never got lucky with just trying to push it in.
Old Aug 24, 2001 | 03:31 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: Compressing rear brake piston??? (KDuniverse)
Pepboys or Autozone sale one of the brake thingie, use that to squeeze the rear piston in. You need to use the old pad to place it against the piston, use the squeezer to push it in, the sueezer has a metal plate that will be place against the other side of the caliper...
I think the front you need a C clamp to squeeze the piston in. The brake squeezer doesn't work for the front (no room for it)
Old Aug 24, 2001 | 03:48 PM
SunCr's Avatar
SunCr
What year Vette? Some GM's (and foreign makes for that matter) require a special tool which for lack of a better description, looks like a square Hex. You use it with a ratchet and twist the piston back into its bore. If you have this setup and try to compress the piston the old fashion way; ie, with a c-clamp, you will ruin the piston. Again, I don't know if your year Vette has it (or if any year does), but a tell tale sign would be if there are any indentations on the outside of the piston for the tool to fit into. If you do need it, the tool is available at any parts store.
Old Aug 24, 2001 | 04:26 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Default Re: Compressing rear brake piston??? (SunCr)
I took a piece of 1/4" flat steel stock about 2.5" wide by 4 inches long. I drilled a 3/8 hole near on of the ends and threaded it for a screw. I then slide the plat where the outside pad goes and turned the screw out to push the piston back into the bore.
Old Aug 24, 2001 | 08:18 PM
JasonL's Avatar
JasonL
Default Re: Compressing rear brake piston??? (Mez)
All you need is a $5 6" C-clamp. Flip the old pad over so the flat pad surface lies against the piston(s), and compress with the clamp. No need to spend your money on any fancy tools...
Same goes for the front. The old brake pad will compress both pistons at the same time.
Don't forget to open the master cyl and suck out some of the fluid first, or it will spill out.
Old Aug 24, 2001 | 10:12 PM
jfb's Avatar
jfb
I did my fronts last week and opened the bleeder valve and pushed on the piston and it went in .
Old Aug 25, 2001 | 12:49 AM
Onyx's Avatar
Onyx
Default Re: Compressing rear brake piston??? (jfb)
thanks for the help guys. $6 piston compressor from AutoZone worked great. I appreciate the help.
To Compressing rear brake piston???
