EDIT: If the port in the top picture goes to the PCV valvem than I have it hooked up wrong (that is where I have the black hose from the port below the open port going) and I will need to know where the lower port (where the black hose is now) goes.
Yes... now I see. You do have three. I am going from memory here because I'm still at work.
The top port is for Fresh Air (PVC system)
The middle one is for your fuel tank vapor canister purge valve.
The bottom one is for a cooling hose.
The coolant air purge line in the back is connected to one of those little hoses that runs to your between your surge tank and the radiator. This is where our model years may differ and someone with an '88 could probably be of more assistance.
The coolant line should go to a tee fitting on the upper heater hose.
There is a flared tube with tube nut that attaches to the fiitting shown, then short length of rubber hose, then a small pipe, then another length of rubber hose that finally connects to the tee in the heater hose.
Currently mine is plugged at the manifold base, ever since my bigmouth/SR installation but someday I will re-connect the hose. I promise.
The rear port connects to an ~3" long piece of 5/16" hardline. This piece connects to an ~10" long piece of rubber line (isolation'flex purposes between the engine and chassis) that connects to another hardline that is secured to the top of the AC blower/heater box. This hardline connects into the small nipple on the rubber heater hose assy near the fenderwell on the '88.
This info is coming off of my factory '88, which differs only slightly from the '86-'87 and the '89.
What are the effects of blocking this off, and do you know the size/thread of the fitting required to do so?
I completely eliminated my EECS and have not had a single problem. Think about those TPI conversion kits on pre-emissions cars. I didn't see any provisions for the EECS in the TPI harness retrofit kit! Anyways, the gas line that goes into the canister is just vented outside my left wheel well. I also put a check valve on it just to make sure water isn't sucked in. Only gas vapors will come out, nothing will go in. If you live in an area where there are no visual inspections, take it out. You are just asking for more places for vacuum to leak out. Finding vacuum leaks can be quite annoying and will make you feel like hitting your car when drivability issues arise.
Blocking the small coolant passage seems to make it more difficult to get all the air out of the cooling system. It took me a few days of burping the rad to get it full. It lets steam/air escape from the rear of the intake.
The fitting in your picture threads into the base. You can remove the fiitting and plug with an 1/8" pipe plug. The fitting itself has an offset.
You may also need to remove the egr block off plate for clearance to remove the fitting.
I had to re-tap my base since I stripped a couple of threads the first time when re-connecting the flare nut. When I tightened the flare nut, it torqued the fitting right out of the base, so be careful removing it. After the stripping incident it was easier to just use a plug, plus I was itching to fire the car up. This was meant to be a temporary fix, but we'll see about that.
