Will AIR Removal Throw Codes?
Old May 18, 2006 | 08:29 AM
danziger's Avatar
danziger
Default Will AIR Removal Throw Codes?
I did a search and looked at Vader's page (very good stuff!), but just wanted to be positive that removing the smog stuff, asides from the cats, won't throw codes. Please advise... Thanks! Ben
Old May 18, 2006 | 08:40 AM
Roger anderson's Avatar
Roger anderson
I removed the air on my 86 coupe and did not throw a code, sure cleaned up the front of the engine.
Old May 18, 2006 | 09:09 AM
87vette's Avatar
87vette
No codes here as well.
Old May 18, 2006 | 09:15 AM
korvette4u's Avatar
korvette4u
no codes here. if you do get one it will be code32 and canbe fixed by placing a diode to ground at the egr sensor wire.
Old May 18, 2006 | 09:32 AM
Steel Blue 91's Avatar
Steel Blue 91
Old May 18, 2006 | 09:59 AM
cdnguyred88's Avatar
cdnguyred88
No codes here either.
Old May 18, 2006 | 10:01 AM
danziger's Avatar
danziger
Sweet! Will I need block off plates? Where could I get them? Thanks!
To Will AIR Removal Throw Codes?
