Easy Question
At the top of the project list now is what did I do wrong? It is running rough now at idle (rpm 8ish) and feels like it is missing when I am driving. I am getting some rear pipe feedback (snap, crackle and pop) when I come off the gas. I assume this is electrical and not fuel related?
The plugs I bought were an R43TS and I gapped them at .035. The book says to use a R43CTS. Is there a difference? Also followed the instructions on how to assemble the wires (had to add on the plug side head). Anybody have any thoughts on what it could be?
Use the process of elimination, and remember KISSKeep
It
Simple
Stupid
Should have mentioned that it's an iron head and not aluminum (I understand most 86's are iron). Also, what's high mileage? I'm in the low 70's (first time around). Please tell me both those problems are gone with this explanation.
No, the IAC (idle air control) is located at the front of the engine..located below the TB.
So we KISS it. Look for old wires to begin exchanging one at a time to see if I can find the offending item. WIFE THREW THEM OUT DURING THE WEEK. Have a melt down. Re-establish rules regarding touching my stuff. BUT, she bought it for me for our 20th so what can I say? I wisely choose to shut up.
Pull every wire one at a time. Check they aren't crossed and they are in the correct order which I believe to be (hope this comes out):
Left side Right side
Cylinders Distr Cylinders
8 l 6-5 l 7
6 l 3---7 l 5
4 l 4---2 l 3
2 l 8-1 l 1
Looking From the Front of car
Everything is fine there. Pull every wire and every plug individually and look. While I have the wires off I resize them because I had them too long. Pull the boot, cut the wire, reset the boot. Make sure every plug is properly screwed in. Make sure every boot is on tight at plug and distributer. Never opened the distributer so shouldn't be that.
Take car out for run. It is running worse! Come back, recheck every connection. Take car out - still awful. Car idles up and down for 30 seconds before quiting. Wound every wire from the distributer to the plug around one another at the suggestion of a friend (touching each other) instead of cleanly separated using separators. Still runs bad.
I'm sure it has to be something simple. Something I did. Could it be the Accel wires? Seating those boots is a pain. I followed the instructions but I don't know. At this point I'm not sure what to do next. Would sure love to drive it!
Rick - to respond to your quote above: How do I check the IAC, I checked on the ACDelco site for R43TS vs R43CTS but no info, never used an OHM meter (I'm a novice) but a friend has one and I'll test the wires.
What is my next step?
8 l 6-5 l 7
6 l 3---7 l 5
4 l 4---2 l 3
2 l 8-1 l 1
I am pretty certain my problem has something to do with the replacements I did and I am sure you are right to rule out oil. I'm sure this is electric which means wires or plugs are probably to blame.
Regarding the firing order - I currently have the cylinder order (looking at the distributer from the top and going clockwise starting in the 12:30position) 5-7-2-1-8-4-3-6! According to information I have and how I pulled them off that is right - right?
The wrapping the wires suggestion came from an early C3 guy. I have a sneaky suspicion that crossing wires may have been advantagous back then but I'm thinking that may not be true any longer. Anyone have a strong feeling on the subject?
Back to the car. I paid $85 bucks for the Accel wires thinking that I would upgrade to the 8.8mm size now in case I add performance mods later (re-mortgaging it two years
. I didn't know they came un-booted from the factory. I was very careful booting them. I guess it's possible I screwed that up. Do I take them off and throw them into storage and go out and buy ACDelco originals (8mm's)? And does anyone know a good site to check whether ACDelco R43TS is the same as a R43CTS plug? I did some checking and they pull the same plug when cross referenced with another brand of plug.
I replaced them with 2 old plugs and everything cleared up and it runs fine. Tomorrow I will go out and replace with new plugs.
Pull the plugs + inspect carefully, ohm them from the cap to the center electrode. (if one is broken it will be open)
Ohm the wires as previously suggested. (you did put the center wire under the crimp end when assembling the plug wires) <sorry>
Don't change the oil (M1 is fine) or check other stuff. (if it did run ok before).
PS: Un-twist your wires. Run them neatly using stock routing.
I did put the center wire under the crimp and used a hammer and the two setting tools they provide to attach the crimp onto the wire. None of the center wires stick out passed the end of the crimp although the center wires seem to have a covering of some kind over them and the directions say not to cut or fray that covering.
I'll let you know what the outcome is. Again - thanks!
Everyone have a great week!
I placed the red probe in the red end of the spark plug wire and the same with the black probe/wire. I turned on the meter and it is bouncing all over the place. Usually from 0 to .250 on the meter. It seems to bounce into the .200 range more often than other numbers.
My question is - what does this mean?
