Heat Control
Old May 19, 2006 | 09:09 PM
bigg321's Avatar
bigg321
2nd Gear
Default Heat Control
DOES ANYONE KNOW IF THERE IS ANY COMPUTERS FOR THE HEAT ON A 91 CORVETTE WHERE IS IT LOCATED? THE PANEL IS NEW BUT I STILL HAVE NO CONTROL BIGG321@AOL.COM THANKS
Old May 19, 2006 | 09:38 PM
c4cruiser's Avatar
c4cruiser
There are two A/C and heat control types. One is a standard system with a sliding lever that controls the amount of heat or cooling. Buttons operate where the airflow is directed (defrost, dash outlets, or floor outlets or a combination)
The other is the optional Electronic Climate Control system. This system uses a digital display to change the heating or cooling temperatures. It also has buttons to operate the air flow controls.
We need to know which system your car has in order to better answer your question.
And please, turn the Caps Lock button off. Using all caps is the Internet way to indicating shouting.
Old May 19, 2006 | 09:42 PM
pablocruise's Avatar
pablocruise
IT'S ON THE DRIVER'S SIDE, ON THE INSIDE OF THE CAR, ON THE FIREWALL, BEHIND THE BRAKE PEDAL, NEXT TO THE STEERING COLUMN, A BLACK PLASTIC BOX, GOTTA REMOVE THE HUSH PANEL
To Heat Control
