Raced a motorcycle--I won.
I had road raced my '92 6 speed w/383 a couple weeks ago. It appeared to be 'cutting out' at 7,200 RPM. The 'limiter' in my TPIS chip is supposed to be set at 7,800 RPM (engine is built for high RPM usage). I was so busy steering and braking, I could not get a 'feel' for the point where the engine would stop revving/miss. Didn't think it was the 'limiter', maybe valvesprings or inferior Opti.
Today I raced a custom chopper and walked away from him, to his surprise. I was hitting this disappointing 7,200 RPM 'wall' in 1st, 2nd, and 3rd (over 110 MPH). The engine has 'more' in it, and I would have smoked him easily if allowed to rev to my desired 7,500 RPM (and without the last second stumble before having to shift). After this, I hooked up my AutoXray scanner, just to read my RPMs. It appears to jive with my 8,000 RPM Autometer tach, give or take 100 RPM. This is until I hit 6,375 RPM, where the scanner stops increasing, and my Autometer keeps going to 7,200, then I am forced to shift.
Of course, this is a question I will pose to TPIS, but I am open to input from the unbiased computer geeks who cruise the CF
.Is this the PROM 'tricking' the ECM into thinking it is at an acceptable RPM for WOT/Open Loop operation without wanting to cut back injectors for limiting RPM? Or, is there some misinformation being sent? My tach filter has been removed, since I have an MSD 6A and full size coil. What I am feeling at 7,200 RPM COULD be what the PROM's limiter feels like, now that I am able to pay closer attention to it.
Anyone want to take a stab at this one?
The rpm signal is only 1 byte, which means it has a max value of 255, with a 25 rpm resolution. 255X25 rpm is where the 6375 limit comes from.
I posted awhile back on how to calculate rpm from the drp, now I have to remember again, its late...
Try 1/(DRP in ms * 4 pulse/rev/1000 ms/s) * 60 sec/min = rpm
Example : DRP 2.79ms
1/(2.79 * 4/1000) *60 = 5376 rpm.
From data master, rpm = 5450, rpm16 = 5371, basically the same value that I arrived at from the drp. Ok, close enough.
A couple more examples:
DRP of 2.09 ms = 7177 rpm
DRP of 2 ms = 7500 rpm
DRP of 1.92 ms = 7812 rpm
You can see very small changes in the drp time have a big effect on rpm.
The ecm rev limiter gets rpm from the drp in a similar fashion within the ecm. This can be a somewhat noisey signal and may jitter in the range of 100-200 rpm compared with something like a filtered tach rpm, resulting in earlier limiting than expected.
You could be hitting your 7800 rev limiter, at an indicated 7200 with a noisey drp pulse signal. I haven't seen this much error, but I think it could be possible. I wouldn't be surprised with a 200 rpm error, 600 maybe? But at this rpm there isn't much margin for error.
My AutoXray does not read dis. pulse or hi/lo res. signals. I will try to get my friend's MAC Tools scanner hooked up and see if it gives any DP readings.
Are we (you) saying that this possible higher RPM error is caused by the LACK of the GM tach filter? It would not be difficult for me to hook it back up--in the past it was in place after I installed my MSD, and would disrupt my factory tach around 3,000 RPM and light up my ASR/traction control idiot light (I was able to rev my old 350 right up to ITS programmed 7,500 RPM limit, no problem!). My Autometer tach has always worked fine, off of the MSD, so I didn't remove the filter until recently, partially due to CF advice and puzzling Opti troubles (which WERE discovered and, supposedly, rectified with a new Opti).
Do I need to have the chip reprogrammed with these issues in mind?
I do know that on my car the drp based rpm signal is kinda noisey, compared to the 25 rpm res signal that is available on the ALDL log.
I would usually have to set my rev-limiter in the ecm 100-200 higher that desired since I noise spike was enough to kick the limiter in early.
When I wanted to be able to achieve 60 mph in 2nd gear (4+3 with 3.73 gears) which would normally require 6000 rpm, I had to set the limiter to around 6200 to not cut fuel before 60 mph was reached. At higher rpms, the noise effects could be even bigger.
The easiest test would be to set the rev-limit higher in the chip and see what happens, maybe something like 8400 for a test.
Due you see the fuel being cut? Look at the bpw/injector duty cycle. This should be 0 when and if the fuel rev limiter is in effect. Sorry I should've mentioned this first.
As for the filter, it is there to clean up the wave form from the coil so the ECM can make sense of it. I think it's a square wave coming out and it gets cleaned, some how... I don't remember the specifics.
I would think that getting into this RPM range, you need to do one of two things, redo the chip so it doesn't have that artifical limit, which means updating it so it has something to work with about 6500 RPM, or, upgrading to a non-opti ignition with an after market engine controller might just solve this.
One warning - the aftermarket ECM more than likely will NOT communicate with the CCM, which means SYS lights flashing and such.
What you may want to do is run the OEM ECM to take up data and feed the CCM. Then run the engine off the aftermarket system. I have no idea if this would work, tho. I am afraid that two computers reading the same sensor could foul everything up.
What would help is if the Gen 7 had a GM compatible Serial Data Link output.
I have an idea... wanna trade? Your opti/coil for my LTCC??? That could be made to work.
Bruce
It is one of the best optical sensors out there.
Im more than happy with a distributor with an external coil/msd 6+
