Dyno Pull This Morning
Old May 20, 2006 | 12:40 PM
qws's Avatar
qws
Default Dyno Pull This Morning
Got my dyno results this morning. First I've ever had it on. The results are slightly lower than I expected but overall am satisfied. I have an 84 CFI, and I think that with the results I got they match up good with the mods I have. I think my next best move will be gears then a cam.
Mods: 160 degree thermostat 180 degree fan switch, RAM AIR,K&N,Headers,X-ram,1.6 RR, Stock CFI
It did run rich midrange, but leaned out again as it went faster. The car ran at 185 degree's the entire time, and a lot of moisture in the air today
Any of your thoughts would be appreciated.
65 mph - 123 mph
Heres a 15 second video of the dyno pull. It was pulled in third gear
http://www.e-watersystems.com/dynovid.3g2
Old May 20, 2006 | 12:54 PM
kopbet89c4's Avatar
kopbet89c4
Well, looks your stock CFI was very underrated. That pass was equivalent to 240 chp and 300 ft-lbs of torque. Right along with a stock TPI
Old May 20, 2006 | 07:33 PM
xrcrx's Avatar
xrcrx
Default x-ram
W/the X-ram and 1.6 rr's did you notice much loss of low end in daily driving? My X-fire is still stock and I have obtained a manifold to port. Everything I've found on the X-ram shows peak improvement with a corresponding loss on the bottom. Great for the track but not the street. Also-your car stick or auto? Thanks.
Eric
84 Z51 Auto
Old May 20, 2006 | 09:27 PM
qws's Avatar
qws
Eric
84 Z51 Auto
You'll read all over that you loose the low end. But I will be honest I feel my low end has improved considerably since my upgrades. I don't have any actual 1/8 or 1/4 miles times but did run 60 ft at 2.2 then 1.76. Whether you port or use the x-ram I would definetly use th 1.6 R.R's. I did forget to write in for my mods that I also put in a B&M shift kit, 2000 TQ. I kept the orginal size TB's thinking that maybe this will help with my low end. I'm not sure if I'm right but am very happy with the low end.
Old May 21, 2006 | 12:12 AM
xrcrx's Avatar
xrcrx
Default Thanks!
Cool! Thanks a lot for the input. Since I
've already got the extra intake I'll probably try it first, then add the 1.6's.
Eric
84 Z51 Auto
Old May 21, 2006 | 12:13 AM
scorp508's Avatar
scorp508
What kind of dyno is that? I don't recognize it.
Old May 21, 2006 | 12:23 AM
qws's Avatar
qws
Heres a link I found, Dyno Dynamics
http://www.dyno.com.au/
To Dyno Pull This Morning
