Whats wrong with my C4?
Old May 20, 2006 | 10:53 PM
Rinker96LT1's Avatar
Rinker96LT1
Default Whats wrong with my C4?
I have taken my 96 in to my mechanic but he can't figure it out. Maybe someone has had this problem before and knows how to address it. My car makes a whine/whistling sound, especially before it completely warms up. When I give it throttle it gets louder then fades away. If I put it into first it is alot easier to notice it aswell. Does anyone have any Ideas? My mechanic said it could be the factory air pump and that the noise is normal, but its never been there before and if it were a normal noise I wouldnt have bought the car.
Thanks,
Jim
Old May 20, 2006 | 10:57 PM
RRT vette's Avatar
RRT vette
Did he check the idler pulley?
Old May 20, 2006 | 11:03 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
I just had to change Lisa's for that very reason.
Old May 20, 2006 | 11:07 PM
Rinker96LT1
all he said is that he heard the noise and brought it back to the shop, popped the hood and figured it was the air pump. But the idler pulley that you replaced was making a whistling noise? I might as well just go put a new one on, 20 bucks and 5 minutes of work.
Old May 20, 2006 | 11:14 PM
the blur's Avatar
the blur
maybe .... possibly a power steering pump.
Old May 20, 2006 | 11:26 PM
cv67's Avatar
cv67
St. Jude Donor '05
Take the belt off and start it. Your mechanic try a stethescope?
Old May 20, 2006 | 11:28 PM
Rinker96LT1
no, he just drove it and said he "kind of" heard it, and said he thought it was just normal noise from the air pump
Old May 20, 2006 | 11:48 PM
AKS Racing's Avatar
AKS Racing
Mine makes a whistling/whine noise too. I know it's not the idler or the PS. But it does stop when you pull the cogged belt.
Just a bit of fun. I would think you have an idler issue as well. How many miles on the car. If you do replace the idler, get one of the original type GM ones, not the "cheapie" that they sell at the local Autozone. I have see a few of these come apart.
Aaron
Old May 20, 2006 | 11:50 PM
Carpenter's Avatar
Carpenter
Your air pump is driven electrically, not by belt. Doubt it's that.
Either an idler pulley or belt driven assessory (a/c or p/s).
Old May 20, 2006 | 11:57 PM
Rinker96LT1
ive got about 68k on her, im gonna try a new idler in the morning, hopefully that does the trick. if not ill be back...
Thanks for all the help,
Jim
Old May 21, 2006 | 12:14 AM
larryfs's Avatar
larryfs
on the LT4, there is another "idler" pulley. It's not a tensioner, but just a bearing with a pulley.
Old May 21, 2006 | 07:15 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Is it also on the LT1? His name includes "LT1", so I'm not sure.
Old May 21, 2006 | 07:42 AM
87vette's Avatar
87vette
My air pump did that as well as my failing water pump.
Old May 22, 2006 | 10:54 PM
Rinker96LT1
FIXED! $15.95 + 8 minutes = no more noise. Thanks for the advice everyone, the new idler did it.
-Jim
Old May 23, 2006 | 12:37 AM
Rich & Lisa_84
-Jim
Old May 23, 2006 | 12:26 PM
VAHROOM's Avatar
VAHROOM
Default It probably isn't the AIR pump
Probably not the AIR pump because the 96 has an electric pump mounted in the left front corner of the engine compartment. It only runs for 20 seconds or so when you first start.
It may be a pulley bearing. Take the belt off when cool. Spin the pulleys and listen. The pulley if having problems may be very easy to spin and will make noise.
Does the sound very with engine speed? Higher pitch, louder, or anything like that?
To Whats wrong with my C4?
