Trying to get this working. Relay is OK, added a ground to the digital dash when I had that out last year.
I just adjusted the cable and found a leak in the rubber diaphram on the servo unit - it looks like only the entire unit is sold (unit = $299 to replace, not in stock).
I was thinking about trying to seal it with some silicone sealer. Anyone have any ideas on this?
Good job!
sometimes these show up on ebay for $25 or so.
Tip: Many GM cars from a wide year range used the same diaphragm and servo. I once found one in a junkyard from a 77 or 78 Caprice that was identical.
