ARP headers bolts and accessory brackets...
Old May 21, 2006 | 09:21 PM
95wht6spd's Avatar
95wht6spd
Default ARP headers bolts and accessory brackets...
do they require any special modifications or mounting brackets for the accessories? I am leaning toward the TPiS headers right now, and you can use the stock bolts, so you can utilize the mounting brackets. I don't want to use stk, I want to use ARP, so will I have a problem with mounting accessories?
Old May 21, 2006 | 09:31 PM
STL94LT1's Avatar
STL94LT1
As far as I know, ARP doesn't make header bolts for the TPIS headers.
With my EM headers I used the stock bolts for the acc brackets and oil dip stick tube, normal header bolts for the rest.
Old May 21, 2006 | 10:05 PM
95wht6spd's Avatar
95wht6spd
No ARP doesn't make a special bolt for TPiS headers, but ARP makes a set of botls for any LT1, that should work with any header. What I am worried about is getting the headers and ARP bolts, and then having trouble mounting the accessories. Some have said they have fabed a bracket? I just want to have my ducks in a row, and most say not to re-use the stk bolts.
Old May 23, 2006 | 09:05 PM
95wht6spd's Avatar
95wht6spd
Ttt
Old May 23, 2006 | 09:22 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
TPIS headers have spacers welded to the flanges to allow use of the stock manifold bolts and to make the use of the stock brackets simple. Unless ARP makes a replacement for the factory manifold bolts, you're SOL. Header bolts will not work w/ the TPIS headers.
Old May 23, 2006 | 10:17 PM
95wht6spd's Avatar
95wht6spd
Well that is strange...I don't undertand why ARP bolts won't work, but I'll take your word for it.
Well I thought it was a "no, no" to use stk bolts or is it just not to RE-use stk bolts? Many people have used the TpiS so I guess there is no real issue? The reason I like the TPiS is they have longer collectors vs. EM, do you think this will make any real power difference, VS a 3" pipe to the rest of the exhaust? I guess it is really about the same, right?
To ARP headers bolts and accessory brackets...
