1992 ALDL Flash Code 34
Old Aug 25, 2001 | 07:19 PM
SLEV89's Avatar
SLEV89
Default 1992 ALDL Flash Code 34
a pal of mine has pulled a 34 Flash Code for a 92
i don't think this means the same thing in 89speak
would one of you brothers help me out?
thanx mates :cheers:
Old Aug 25, 2001 | 08:08 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: 1992 ALDL Flash Code 34 (SLEV89)
In 95 (speak) it indicates MAP sensor circuit-signal voltage low-high vacuum.
Old Aug 26, 2001 | 12:28 AM
KYVette90's Avatar
KYVette90
Default Re: 1992 ALDL Flash Code 34 (lou sylvestri)
Possible Vacuum leak. Check the vac hose on the MAP sensor. Also unplug the map connector and clean it out with elect.parts cleaner and plug it back in and reset the computer. Map sensor could also be bad.
Old Aug 26, 2001 | 04:23 PM
SLEV89's Avatar
SLEV89
thanx a lot guys,
he had his tranny serviced and they (of course) wanted to go deeper :eek:
since he left the station it stalls with no throttle, and 34 is prevalent.
definitely could be a vacuum problem - those buggers probably pulled a line!
i'll get back to you...
To 1992 ALDL Flash Code 34
