94 LT1 Opti Replacement Report
· Replaced Intake manifold gaskets
· Replaced water pump
· Replaced Optispark (modified new opti for fresh air venting)
· Replaced timing cover gasket and the three seals in the cover
· Replaced oil pan gasket
· Replaced wires
· Replaced plugs
· Radiator was cleaned and flushed by Dougan’s Radiator
· Replaced all cooling and heater hoses
· Replaced knock sensors
· Flushed engine block
· Flushed heater core
· New Antifreeze
· New Oil
· Replaced Air Cleaner
· Replaced expansion tank cap
It took me 59 hours to do this work, which includes the removal of the opti three times. READ ON. I could do it in half the time the next time. The entire job took about four weeks. I had to wait numerous times for parts and special tools. I bought the tool to install the WP seal in the timing cover and I’m glad I spent the money. I had a heck of a time getting the crank hub off but now I know how to do it in 15 minutes. I must have wasted 5 hours trying to get the damn thing off. I modified the opti using the tech article in Corvette Fever. When I went to install the newly modified opti I found that the mod to the cap hit the crank hub, argh! I ended up sealing the holes in the cap with the Plastex repair kit and cutting new holes. The dremel tool cut through the opti cap like it was butter. I finished the work and the engine started right up. I thought I was home free. NOT. After a test ride I noticed a puddle of oil under the car. After investigating I found oil on the front of the oil pan
. I figured the WP seal was leaking because that’s what everyone talked about on the forum as being the most likely leak area. So, I took the WP and opti off again. The timing cover was dry. I installed the WP seal correctly with the help of the Kent-More tool. ($45 for a little plastic tool). I figured it must be the oil pan gasket leaking because I didn’t replace it. I just dropped the pan to free the timing cover and put the pan back up. I replaced the oil pan gasket, installed the WP, opti, and filled the engine with coolant. Thinking I was done I took it for a ride. Came back, parked it in the garage and there’s the puddle of oil AGAIN!!! Now I decided to get scientific and I put dye in the oil (should have done this in the first place). With the UV light and a mirror I looked at the front of the pan and when I looked at the crank hub seal I could see it was leaking. Off comes the WP and opti AGAIN. I checked with the UV light to make sure the WP seal and opti seal wasn’t leaking and they were dry. The damn crank hub gave me a pain again but as I said before I know how to do it now. The crank hub had a score line where the old seal was. I just overlooked this the first time around. Another lesson learned. I installed a felpro sleeve and new seal. NOW it doesn’t leak. The total for all the parts came to $1200. Sure adds up. Oh, did I mention when I was removing the hose on the passenger side of the throttle body the metal inlet broke right off? That was $100 for the housing that goes on the bottom of the throttle body. This concludes my Opti Modification report. I took lots of pictures. If your in the CT area and need help with and opti mod look me up. I may have it right by that time. I want to thank all the forum members who provide advise and support.
Thanks Guys
Tom Powers
Tom Powers
Tom Piper
The pictures are for reference when I put it back together. I didn't take the picture of the puller attached to the hub.
