EPROM TCC Lockup question
Here are some questions for the PROM folks:
1. I've gleaned from posts on thirdgen that "Low gears" means gears 1-3, and "high gear" is OD or 4th. Is this right?
2. There are TCC values in tables and in constants. Are the constants an overriding "master rule" regardless of what's in the tables, or is it for WOT or no throttle? How do I use the constants?
If I never want the converter to lock under 40MPH in 1-3 gears, would this work:
low gear Constants: TCC Unlock speed to say 1MPH, Lock to 150MPH?
low gear TABLES: Put all tps% in LOCK table to .1 and all in ULOCK table to 99.9?
Now I'm thinking I may be backwards. I really need someone with some experience to help. I'm so confused :crazy:
A few of us from the Corvetteforum are members over there as well. I've been a member there for a few months and think I've reached four or five posts. Most of my questions are found in the archives so I need not ask again
Good Luck!
Cory
