MSD Distributor conversion
Old May 27, 2006 | 01:48 PM
corvette90's Avatar
corvette90
Default MSD Distributor conversion
Hi all
i want to install an Holley Stealth Ram (modified) , so i have to use a small cap distributor
have anybody done this?
which parts will i need?
currently, i have the stock HEI distributor with a DUI cap and coil
best regards
Old May 27, 2006 | 04:04 PM
-=Jeff=-'s Avatar
-=Jeff=-
Cruzin performance use to (might still) sell a wiring kit for that conversion. Simple to convert. I did it with my miniram set-up, Gives me more space around the back
Old May 27, 2006 | 04:09 PM
Slalom4me's Avatar
Slalom4me
Since it is a Stealth Ram, the info about it is hiding in a thread
about the Super Ram.
See if this post tells you what you want to know about
[insert subject here] regarding using the HSR in a C4.
Incidently, the adapter harness mentioned in that post is
somewhat expensive. I do not know what the availability
of connectors or used parts is like in Austria - making your
own harness may not be an option. But check with the
alternate vendor mentioned in the post to comparison shop.
To MSD Distributor conversion
