Opti connection question
May 27, 2006 | 08:08 PM
I had to get to a broken bolt that hold the belt tensioner in my 92 Coupe (LT-1). In doing so the single wire (not any of the 8 plug wires) got disconnedted from its source (not from the Opti). For the life of me, I can't locate where it goes to ..... I don't remember disconnecting it. I do not see any diagrams in the Haynes manual.
Can someone point me to whaere this wire goes...
Thanks,
Al
May 27, 2006 | 08:11 PM
Ignition coil wire? It's located on the front of the passenger side cylinder head.
May 27, 2006 | 08:17 PM
Quote:
May 27, 2006 | 11:25 PM
it is a plug wire looking thing? or is it more of just stranded insulated wire? Where you are working, it could be the temp sensor...
May 28, 2006 | 01:29 PM
Quote:
I'ts definitely the plug wire coming off of the Opti.
May 28, 2006 | 01:31 PM
May 28, 2006 | 01:40 PM
yup... coil... short? goes to the coil.
May 28, 2006 | 04:33 PM
This pic should help.
