4.09 or 4.10?
Old May 27, 2006 | 08:08 PM
56chevynut's Avatar
56chevynut
Default 4.09 or 4.10?
Hi guys, I noticed you can get both a 4.09 and a 4.10 ring and pinion for the Dana 44. Why do they make both of them since they're so close in ratio? Which is better since they have a different number of teeth, 45/11 versus 41/10. Any ideas or suggestions?
Old May 27, 2006 | 08:16 PM
bogus's Avatar
bogus
get the 41/10. Less teeth = stronger gears.
Old May 27, 2006 | 08:23 PM
STL94LT1's Avatar
STL94LT1
4.09's have a steel sleeve welded on the pinion shaft, 4.10's have the correct pinion size without the steel shaft. The 4.10's will be stronger.
Old May 27, 2006 | 09:38 PM
500hp's Avatar
500hp
The 4.10s I am familiar with are usually made for the Corvette's unique HD Dana 44. Most others are modified or require special parts for installation into the C4's 44 carrier/housing. I think they may be originally manufactured for Chrysler or 4WD truck applications. Spend the little extra and get the correct '84/'89-'96 Corvette D44 4.10s.
Old May 28, 2006 | 12:02 PM
96 lt-4's Avatar
96 lt-4
yes sir.i wasnt aware of the difference when i purchased a set of 4.09's.now i have a set of each.i dont have a boat so i cant use it for an anchor
To 4.09 or 4.10?
