Rack and Pinion Ratio
Old Jun 9, 2006 | 02:52 PM
ccford's Avatar
ccford
Originally Posted by CentralCoaster
Here's some rack info from Delco's catalog, and some codes:
84-85
YM 2.5 turns AC-Delco 36-16252
AJ AK YP 2 turns AC-Delco 36-16303
84-87
CA WL WU 2.5 turns AC-Delco 36-16305 (um, two base model 84-85 racks? wtf?)
86-87
WT 2 turns AC-Delco 36-16306
88-92
w/17" wheel AC-Delco 36-16352 (presumably, 88-91 Z51/2/FE7 cars)
88-96
w/16" wheel AC-Delco 36-16228 (presumably, 88-92 base model cars and all 93+ cars)
If I were you I'd get a Z51 rack out of a 88-92
If I ordered the 88-92 17" wheel rack No. 16-16352 would that be the fast ratio or would I need to get the 86-87 16-306? If I need the 86-87 rack, would that be compatible with a 93?
Thanks Again!!
Old Jun 9, 2006 | 02:57 PM
Vetracr's Avatar
Vetracr
Thanks Again!!
The Delco part is 99.99% the slow rack. They stopped making the fast racks in 88. An 86-87 rack won't fit.
Larry
Old Jun 9, 2006 | 04:18 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by Vetracr
...replacement 89 racks are all the slow ratio.
You cannot order a fast rack for a 93 from a dealer. They were gone years ago. If you want one to fit a 93 you have to order a rebuilt 89 Z-51, code NS rack.
Are you saying the 89Z rack is discontinued, but still available reman? These AC-D numbers are all reman.
If there's no fast ratio thru 92, then why are there two p/n's?
AC-D shows the p/n based on what applications they are direct replacement for, and not necessarily what years they'll actually fit. If their catalog is correct, it sounds like a 92 cutoff.
Either way, all 84-87 racks should fit 84-87, and all 88-96 racks fit 88-96.
Old Jun 10, 2006 | 07:13 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Ecklers lists a reman. 1988 NS rack in their current catalogue for $229 plus core if anybody needs one.
