high pitch humming
Old May 28, 2006 | 10:50 AM
cruzin89's Avatar
cruzin89
Cruising
Default high pitch humming
what would cause a high pitched humming in the engine
Old May 28, 2006 | 01:34 PM
Civis's Avatar
Civis
Is it a steady pitched whine, or does it rise and fall with engine revs like a blower or gear drive? Does it do it when starting, idling, driving, accelerating, deccelerating, or all the time that the engine is running? Cold or hot? In gear or not? Did it just start happening?
Old May 29, 2006 | 09:44 AM
cruzin89's Avatar
cruzin89
Cruising
Default thanks for responding
the noise is constant but rises and falls when accelerating. Strange that I can also hear it thru my speakers when the radio is turned on. It did just start happening.
Old May 29, 2006 | 09:47 AM
Pete K's Avatar
Pete K
Remove the belt and run the engine for mo more than 20 seconds to test it. If it goes away when the belt is removed, it is an accessory. Likely the alternator.
Old May 29, 2006 | 09:50 AM
cruzin89's Avatar
cruzin89
Cruising
Thanks for the info---alternator was my thought.
To high pitch humming
