Which engine oil cooler should I use?
Old May 28, 2006 | 11:27 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Default Which engine oil cooler should I use?
I want to put an engine oil cooler on my "90 Vette L-98. The one from TPIS is just a little "PRICEY" if you know what I mean!
What system are you using?
Where did you buy it from?
Approx. how much?
What's the part number(if possible)?
What is involved(Do I have to take the stock setup off-i.e water hoses)?
Any suggestions would be great!!!
I would like one that bolts onto the stock if possible.
Thanks Matt
Old May 28, 2006 | 04:00 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
I am installing one this evening and will report back after I test it out and give you an idea of how much cooler the oil is with the cooler that I selected.
It is supposed to be 90+ tomorrow and this should help me get some good numbers for you.
Old May 28, 2006 | 07:24 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Old May 29, 2006 | 03:11 PM
Rich & Lisa_84
Well I am back from my test drive.
Before the oil cooler I was running a water temp of 167 to 174 and an oil temp of 240+. This is with the air temp being 70 or below.
After the oil cooler I am running a water temp of 174 and an oil temp of 196. The air temp is 87.
That is the drop that I was looking for.
I installed the cooler about 8 inches in front of the radiator. It is against the fiberglass air splitter.
I also used about 8 feet of copper tubing which did not come with the kit.
I had to use a different oil filter. The one that I am using is for a SBC 307cu.in.
My oil pressure dropped 8 psi and is holding steady at 62psi.
The price of the kit was $79.88 at Summit Racing.
Here is what I used.....
Brand: Flex-a-lite
Product Line: Flex-a-lite Standard Engine Oil Coolers
Overall Height (in): 5.000 in.
Overall Width (in): 20.000 in.
Overall Thickness (in): 0.750 in.
Cooler Construction: Tube and fin
Cooler Material: Copper/Aluminum
Inlet Size: 1/2 in.
Inlet Attachment: Hose barb
Outlet Size: 1/2 in.
Outlet Attachment: Hose barb
Number of Cooling Rows: 4
Core Height (in): 5.000 in.
Core Width (in): 17.250 in.
Core Thickness (in): 0.750 in.
Cooler Finish: Natural
Quantity: Sold as a kit.
Notes: Spin-on oil filter adaper fits 3/4 in., 13/16 in., 18mm, 20mm, and 22mm threads.
Old May 29, 2006 | 03:15 PM
Rich & Lisa_84
You can order that kit with an extra adaptor, if you wish to keep using the same filter that you currently have. Check with Summit about this.
I opted not to.
Old May 30, 2006 | 12:39 AM
madmatt9471
Thanks for all the info. It is very appreciated. Again many thanks. Matt
To Which engine oil cooler should I use?
