"Groaning" from the front
Old Aug 26, 2001 | 03:35 PM
1Patriot's Avatar
1Patriot
Default "Groaning" from the front
When doing u turns and other sharp turns, there appears to be a groaning sound from the front of the car. Power steering fluid is at normal level and appears to be in good condition; not black or severely discolored. The drive belt is not cracked or shiney.
Ideas anyone???
[Modified by 1Patriot, 10:36 PM 8/26/2001]
Old Aug 26, 2001 | 04:17 PM
SLEV89's Avatar
SLEV89
Default Re: "Groaning" from the front (1Patriot)
appears to be common for our model
haven't heard of a 'fix' for this
i should change out my Steering Fluid anyway
Old Aug 26, 2001 | 06:09 PM
1Patriot's Avatar
1Patriot
Default Re: "Groaning" from the front (SLEV89)
SLEV89,
Thanks for the recommendation. Some time I think it just needs to be driven more to keep all the seals in the Rack & Pinion lubed well. Maybe it will go away on its own
[Modified by 1Patriot, 1:09 AM 8/27/2001]
Old Aug 26, 2001 | 11:18 PM
TJR's Avatar
TJR
Same symptoms here, I assumed it was low fluid but I haven't checked yet. Guess I won't worry too much about it now.
Old Aug 27, 2001 | 12:35 PM
1Patriot's Avatar
1Patriot
Still looking for solution; any more ideas, folks??
Old Aug 27, 2001 | 01:45 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Make sure your power steering pump is bolted on securely. Some groaning is caused by loose PS pump bolts. All C4's will groan if turned to the locks. BTW, mine groans too!
Old Aug 27, 2001 | 01:48 PM
scorp508's Avatar
scorp508
Positive it's from the front and not the rear? I don't doubt you, just want to rule out the differential fluid.
Old Aug 27, 2001 | 02:11 PM
SLEV89's Avatar
SLEV89
Default Re: (scorp508)
scorp,
good thought.
but mine, when it does choose to happen, produces a significant vibrational feedback through the steering wheel.
also, mine will only really do this when i turn the wheels when static, or close to static, which i do very rarely - always rolling.
Old Aug 27, 2001 | 02:40 PM
thedarkone101's Avatar
thedarkone101
i agree!! i thought for well over a year it was up front somewhere and come to find out, when i had a new rear put in they never bothered with the additive. I changed gear oil last week and added a bottle of additive and it is perfect now. I cant tell you how many people thought it was the pump or the rack or the tensioner. Nothin but a $7 bottle of additive :cheers:
Old Aug 27, 2001 | 03:41 PM
1Patriot's Avatar
1Patriot
Scorp,
Yes, it is definately from the front and the steering does not have to be at max. All of the mounting hardware has been double checked. This is a new condition, car has 38K miles; started about 100 miles ago. We put it on a lift and the noise is not there when the steering wheen is turned through the limits both left and right. But on the ground and rolling, then the noise is present. Discovered it when turning with the window down, it is barely perceptible when the windows are closed and the air is running.
Also the tires are in excellent condition and no unusual wear patterns.
[Modified by 1Patriot, 10:43 PM 8/27/2001]
Old Aug 27, 2001 | 04:35 PM
mshipon's Avatar
mshipon
Cruise-In I Veteran
I also notice a "groaning" or creaking sound when starting out and think it comes from the front. Could it be the shocks? Just a guess...
Old Aug 27, 2001 | 05:35 PM
Edsred96's Avatar
Edsred96
Ideas anyone???
Groaning??? Maybe you ran over an animal or person and they are groaning? :D
To "Groaning" from the front
