info needed on remote starter
Old May 30, 2006 | 07:28 PM
mtlwiz's Avatar
mtlwiz
Default info needed on remote starter
91 l98, has anyone evere hooked up a remote starter for adjusting valves doing it by themselves? if so can anyone explain to me where to make the hookups? thanks,mtl
Old May 30, 2006 | 07:42 PM
CFI-EFI's Avatar
CFI-EFI
Your starter motor (solenoid) has two electrical connecting posts. One is large for the battery cable and the other (a small one) is for power for the primary side of the starter solenoid. Electrically, insert your switch between the two posts on the starter solenoid. Don't forget to pull the pink "Battery" wire from the side of the dist cap, when using the switch, to make sure it doesn't start on you when you least expect it.
RACE ON!!!
