Automatic shift points
Old May 31, 2006 | 03:17 PM
Snuffy's Avatar
Snuffy
Default Automatic shift points
I followed an article I found on this forum and adjusted my transmission cable (1988 auto) as described. Now the shift from 1st to 2nd on light accelration is at about 1500 to 1700 rpm and similarly from 2nd to 3rd. It is a nice firm shift but a little high on the rpms I think?
Does this sound about what everyone else sees?
Old May 31, 2006 | 03:27 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I'm interested in which colum you where you found this at. What is the title? I also want to check mine and possibly adjust it!
Thanks, Matt
Old May 31, 2006 | 07:12 PM
CFI-EFI's Avatar
CFI-EFI
The cable for the 700R4 (4L60) transmission is a TV (Throttle Valve) cable. It is not a "kick down", down shift, or any other kind of "variable adjustment" device. If the article was for the FSM adjustment of the cable, you are right where you belong. The cable is NOT to be adjusted to alter shift points or shift quality. To play with the specified cable adjustment can easily cost you a transmission. Shift points can be manipulated by recalibrating the governor by experimenting with different weights and springs.
RACE ON!!!
Old May 31, 2006 | 08:05 PM
Snuffy's Avatar
Snuffy
This article was found at http://www.tvmadeez.com/article/index.php.
I thought it was a well written and very explanatory article.
Old May 31, 2006 | 10:50 PM
Pete K's Avatar
Pete K
RACE ON!!!
Heed this advice.
Old Jun 1, 2006 | 05:04 AM
SK.LT1's Avatar
SK.LT1
Originally Posted by Pete K
Heed this advice.
To Automatic shift points
