Automatic shift problem
Old May 31, 2006 | 05:22 PM
choopes's Avatar
choopes
Default Automatic shift problem
My 93 coupe has a shift problem with the automatic transmission. When cruising down the hiway at a slow speed of 55-65 I can hear it try to shift from 3rd to 4th. This is easily overcome be either speeding up, or slowing down. Now that it’s summer time I’m giving serious consideration to selling her, and I need to fix the problem. Is there an adjustment to correct this?
THANKS!
Old May 31, 2006 | 07:02 PM
MTVette's Avatar
MTVette
The 700R4, standard issue for a 93 auto, is a three-speed transmission. The fourth gear you experience is just the torque converter locking up. This lockup is controlled by the computer. IIRC, the standard chip sets the lock-up speed around 52-55 mph. If you're driving at that speed, the TC can lock and unlock depending on throttle setting. An aftermarket chip will usually set this speed to a lower speed, perhaps around 45 mph, depending on the tuner. From what you describe, the behavior is normal.
Old May 31, 2006 | 09:17 PM
aminnich's Avatar
aminnich
Are you sure?? Isn't the 4L60 std in the 93s? ps--the 4L60 IS a 4 speed and if (big if) I am right then you probably need a TV cable adjustment.
Old May 31, 2006 | 09:30 PM
Pete K's Avatar
Pete K
700r4 and 4l60's are known for killing the 3-4 clutch pack first. Not always, but usually. They are also prone to torque converter "chuggle". This is locking and unlocking of the torque converter sometimes caused by a failing torque converter. Both problems involve removal of the trans for repair or overhaul.
Old May 31, 2006 | 09:46 PM
aminnich's Avatar
aminnich
Hi Pete, Which one would have been in a 93 model and why would someone say only a 3 spd auto? Am I missing something?
Old May 31, 2006 | 09:50 PM
Pete K's Avatar
Pete K
All 700r4, 4l60 and 4l60e models were 4 speed only models. All were equipt with lock up.
Old May 31, 2006 | 09:53 PM
aminnich's Avatar
aminnich
That's what I thought. And by the way my 4L60E is running great since we last talked, no problems now.
Old May 31, 2006 | 10:33 PM
Pete K's Avatar
Pete K
Knock on some wood
Old Jun 1, 2006 | 01:19 AM
xrcrx's Avatar
xrcrx
Default 3spd
All automatics from 82 on were 700R4-4L60 variants. All are 4spd auto trans. The 4th gear is a .7 overdrive. In gears 2-4 the torque converter also locks at different speeds and RPM's depending on load, speed,etc.... The TV cable is NOT an adjustment cable for shift points.
Eric
84 Z51 Auto
05 Repsol Rep
00 TLR 1000
Old Jun 1, 2006 | 11:57 AM
choopes's Avatar
choopes
Default adjustment
I was told once that there is an adjustment on the left side, over by the computer to control when the shift to 4th (or overdrive) . I don't think this has been normal for the car in the past. Perhaps as a new problem that could indicate future transmission problems?? It's shift-shift-shift-shift at about 55. It seems to do this more then it used to.
Wish I'd gotten a 6 speed manual. Couldn't find that in the polo green. Any suggestions appreciated.
Old Jun 1, 2006 | 06:40 PM
aminnich's Avatar
aminnich
Best thing until you get it into a shop is use the non-overdrive gear shift selection. If it is constantly shifting in and out of OD it won;t last very long at all. Mine is all electronic, but I have seen numerous posts about the TV cable adjustment. Some say it is really simple, others say you mess it up and you will be buying a new trans real soon. Only thing I am sure about is PeteK knows his stuff. Good luck with it and hope it turns out minor. ps--M6s are more fun and might last longer, but transmission repairs are expensive no matter what.
Old Jun 1, 2006 | 10:46 PM
Lichen's Avatar
Lichen
Forget about messing with the TV cable. I had the same exact problem. I had the tranny rebuilt with HD parts, shift kit and hi-stall converter. The problem became even more pronounced. Between 51 and 53 mph, you could feel the car surging and watch the tach going up and down. Now this is weird, and I have no explanation for it, but replacing my worn brake booster cured it. I have no idea why. Doesn't seem like they should be connected in any way. Maybe the vacumn leak was messing with the RPM's, causing it to shift up and down. Maybe it was just coincidence. Maybe it was a miracle. But it worked.
Old Jun 2, 2006 | 04:38 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Your lock up converter switch is in the same location as your brake light switch.
Also adjust your TV cable,if you don't know how PM me.
To Automatic shift problem
