super/turbo charger?
Old Jun 1, 2006 | 04:04 PM
deadSpace's Avatar
deadSpace
Default super/turbo charger?
do any of you guys have any info about good super or turbochargers? where to buy, what to look for, price, etc? any info would be great, thanks!
Old Jun 1, 2006 | 04:14 PM
bogus's Avatar
bogus
the sad reality, there are no turbo kits for the C4...
your profile says you have a 1987.
I don't even know if Vortec is still making blowers for that vintage...
Old Jun 1, 2006 | 04:16 PM
deadSpace's Avatar
deadSpace
that is depressing...
yeah, an '87.
Old Jun 1, 2006 | 04:21 PM
bogus's Avatar
bogus
what you might want to do... scavage... you may be able to cobble together a Callaway type setup.
HOWEVER!!!!! And this is important, a stock L98 will not last long under the stress of forced induction.
You might check ebay for a used blower... check the salvagers, too.
Old Jun 1, 2006 | 04:24 PM
bill mcdonald's Avatar
bill mcdonald
you will want to go to the forced induction section of the forum and post there.
http://forums.corvetteforum.com/forumdisplay.php?f=87
All of the supercharger/turbo guys are there.
I am pretty sure procharger has something for your C4
Old Jun 1, 2006 | 04:29 PM
bill mcdonald
They never did for the TPI's
Paxton had that market.
Old Jun 1, 2006 | 04:39 PM
bogus's Avatar
bogus
I knew it was one of them! thanks for the clarification!!
Old Jun 2, 2006 | 08:55 AM
deadSpace's Avatar
deadSpace
great, thanks for the help. i'll try that other forum, and at least i have some names to research now. thanks!
Old Jun 2, 2006 | 09:02 AM
Pete K's Avatar
Pete K
Research it carefully. I had an ATI procharger set up and hated it. The con's outweighed the pro's, in my opinion. Removed it and sold it to a friend. He loved it for all the reasons I did not. When the supercharger let go, it hurt his new motor. Most may disagree, but I have been there, done it, had the shirt and moved on.
Old Jun 2, 2006 | 09:04 AM
deadSpace's Avatar
deadSpace
could you go into a little more detail? what he liked that you hated?
Old Jun 2, 2006 | 09:09 AM
Pete K's Avatar
Pete K
Noise- 102 decibels at idle. Makes you the center of attention whereever you go.
He liked the wow factor when you put up the hood.
I hated the fact that engine bay was cluttered up. Maintenance was tough with all the extra stuff. Blower smacked the hood under accelleration.
Made a ton of extra heat. More than you would think.
Boost took nearly forever to build up. Maybe that is an exageration, but centrifical blowers need time to "spool up" Boost is not instant like a roots type blower.
FMU pounds the injecters with double the fuel pressure under boost to get the fuel needed.
Belt driven blowers sap alot of power to turn. Make the car feel like the ac is on when not in boost.
Old Jun 2, 2006 | 09:18 AM
deadSpace's Avatar
deadSpace
those sound like pretty good reasons. let me ask you something else then: the reason i started researching turbos/supers is b/c it doesnt seem right that the bhp on that car is so low (if i remember correctly, its 186hp), but there also doesnt seem to be much i can find that increases that reliably.
i keep hearing from people who know cars (but not vettes specifically) that that number sounds extremely low and might have something to do with really poorly designed emmissions controls, and that taking certain parts off the car should fix the hp problem, but i cant find any info on that either. so heres the question: what, other than a turbo/super, can be done to make a c4 perform better?
Old Jun 2, 2006 | 10:04 AM
rickneworleansla's Avatar
rickneworleansla
Not too familiar with your year but here are some links below to get you thinking. Hope they don't mind me posting them. And then theres always the easy route and my personal favorite so far... add nitrous
http://temp.corvetteforum.net/c4/vader86/
http://temp.corvetteforum.net/c4/joe90/index.shtml
There is a company looking for an early C4 to install and test a turbo kit on. I think they are doing it labor free. Can't remember the site though.
Old Jun 2, 2006 | 10:13 AM
bacardioil's Avatar
bacardioil
Get in touch with Greg at blowerworks.com
Gregs a great guy, will steer you right.
Old Jun 2, 2006 | 10:17 AM
AKS Racing's Avatar
AKS Racing
'87 vette - 240 BHP.
Can be made to operate well with ProCharger package. With FI, a relatively mild motor can be run with much more radical NA motors. Peruse the FI/N2O forum and you should see lots of info that applies.
Pete's comments on the early style ProChargers may be very close to accurate with regard to the 102Db level. But, not all blowers have the straight cut gears that cause that level of noise. I run a ProCharger on mine that you can not hear at idle, or any other time over the noise of the motor.
See "My Corvette Photos" for pics of an install on an '87.
Aaron
Old Jun 2, 2006 | 01:01 PM
Pete K's Avatar
Pete K
I admit that I am one of the rare few that did not like mine. Most are pleased. Have a good look in the Supercharger section of c-4 forum. Lots of good info in there. I am not trying to discourage you from buying one. Just remember any major mod requires compromise. No such thing as free power. FWIW, I am a Nitrous fan though. Most people are not
Old Jun 2, 2006 | 01:02 PM
deadSpace's Avatar
deadSpace
yeah... it seems like most people are one or the other. i'd rather stay away from nitro., personally.
To super/turbo charger?
Old Jun 2, 2006 | 01:11 PM
Kurac's Avatar
Kurac
Have you ever thought about a head/cam/header package, and in your case with the L98, a different intake as well? There's something to be said about an all motor car that is done right that can put down some good numbers.
Old Jun 2, 2006 | 01:14 PM
Pete K's Avatar
Pete K
Yep, I generally don't tell others NOS is the greatest thing either. Everyone has a preference. For me it is nice. My car can lay down a decent number off the bottle, but when i want to goof off or brag, I can hit the button and drop over 1.5 seconds off the et. Other buddies will only build large cube na motors. All opinional. Lots to read on the forum. Good info throughout.
Old Jun 2, 2006 | 01:23 PM
deadSpace's Avatar
deadSpace
thats what i would prefer, any recommendations for where to get more info on that?
