Clunk when putting in Drive
Old Jun 1, 2006 | 09:36 PM
rmendoza's Avatar
rmendoza
Default Clunk when putting in Drive
My '90 is new to me and I'm working out all the little things. My wife fell in love with it and wants it when I'm ready to move up! OH BOY the green light, when I get some cash, so I have to make it safe and mechanically sound.
When putting it in Drive, there seems to be a slight delay followed by a noticable "Clunk". It is not as noticable when putting it in Reverse. I also notice it slightly when slowly accelerating as it goes through the gear changes. When accelerating quickly through the gears it isn't noticable. Other than that the drive train seems fine.
Is this a differential problem or tranmission?
Old Jun 1, 2006 | 10:21 PM
bogus's Avatar
bogus
donno... a small thud is one thing, but I donno who to describe it.
ask Pete K
Old Jun 1, 2006 | 10:26 PM
Lichen's Avatar
Lichen
I have a HD auto, and it clunks when I put it in first, but no delay. Maybe somebody installed a shift kit.
Old Jun 1, 2006 | 11:33 PM
vader86's Avatar
vader86
Could be tranny, but U-joints would also cause a clunk going into gear.
Old Jun 2, 2006 | 05:29 AM
Joe C's Avatar
Joe C
i have the clunk on my 85 - i also had bad u-joints. after i replaced the u-joints (all six), i still have the clunk. i suspect a worn differential (noticed some play in the differential, but didn't notice any play the the transmission). i'm presently replacing my rear hub/bearing assemblies, and i do have a small amount of play in the differential. since this is a costly unit to replace, and just might be beyond my "home shop" capabilities to rebuild, i'll just live with it. i have noticed that when parking, if i apply the e-brake while still in drive (or reverse) - prior to putting it into park, i don't seem to have the clunk the next time it goes in gear. i think that little e-brake procedure somehow locks in some little pre-load thing on the ring/pinion gears - ???. (original poster) give the e-brake thing a try and let me know if it works for you.
Old Jun 2, 2006 | 06:28 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Check your U-Joints, had this problem and the u-joints were bad(dried up,17yrs. old Yah Know!),replaced problem solved. Check first if bad "Then" replace.
Hope this helps! Thanks,Matt
Old Jun 2, 2006 | 07:11 AM
RRT vette's Avatar
RRT vette
Another vote for U-joints. As you described, my 85 did this before replacing U-joints.
To Clunk when putting in Drive
