Need engine re-done
Old Jun 1, 2006 | 11:01 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Default Need new motor 383?
I need some input on re-doin' my motor, as I think I spun a bearing. I was looking at an LTx shortblock with:
Chevy 383ci LT1 Street/Strip
Short Block
The 383ci LT1 short block is the perfect start for your engine project. You get a block with crank, rods, pistons, cam bearings and freeze plugs already installed. Plus, the extra stroke of the 383 will give you better torque over a 350. This is the same short block we use to produce out 383ci/400hp LT1 and 383ci/375hp long block engines.
Block: Thermally cleaned and Stainless Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed. 4-bolt main caps and ARP main studs.
Crank: Eagle cast steel, internal balanced front and rear
Rods: Scat 4340 forged steel, 6” length, floating pin.
Pistons: Keith Black HyperEutectic (Upgrade to SRP Forged Pistons for an extra $300)
Rings: Speed Pro Plasma-Moly
Bearings: Clevite Main and Rod Bearings
Core Plugs: Brass Pioneer core plugs
Dynamic Balancing: Full rotating assembly dynamic balancing
Main Studs: ARP performance main studs
I was wanting to know if My LT4 intake, LT4 heads and Hotcam would go well with this short block. I also have EM longtubes.
Old Jun 2, 2006 | 12:09 PM
TOO_HOTTVETTE
ttt
Old Jun 2, 2006 | 01:18 PM
sothpaw2's Avatar
sothpaw2
Short Block
Yes, you can re-use your LT4 stuff and the cam. If you were going for max hp out of the 383, of course, a bigger cam and ported heads would be best.
What caused the spun bearing? whatever that was (?road course) you should of course avoid that in the future. Also, I had bad luck with all this, as 2 days after I got the shortblock installed in the car and drove away an SUV hit the car and ruined it. Guess what? It's not too easy to get your money back.
To Need engine re-done
