This cant be good
Old Jun 2, 2006 | 06:03 PM
mudslide's Avatar
mudslide
Default This cant be good
Now that I got the car running good comes the fun. In this pic the air coming in goes into the pockets and back out causeing a huge turbulance. I dont care what they say about the device that covers the pockets and smoothes the air coming in,but I got to think it has to help--What do you think guys
Old Jun 2, 2006 | 06:07 PM
RRT vette's Avatar
RRT vette
Negative good buddy, If you are refering to a Air Foil. I had a air foil in my 86 TB and it caused a decreased air flow to the IAC passage. I is just a plain waste of money. Doesn't do much for turbulance either. If the air foil is what you talking about.
Old Jun 2, 2006 | 06:39 PM
bogus's Avatar
bogus
yup, air foil.
the idea is sound, until you realize that at speed, the air will pocket that area and create a low pressure eddy that will create an invisable air foil.
no more problem.
besides, it does screw up the IAC.
Old Jun 2, 2006 | 06:56 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I can't help but wonder though. If it doesn't do any good, why are all of the aftermarket TBs already designed that way?
Old Jun 2, 2006 | 07:00 PM
Aardwolf's Avatar
Aardwolf
Old Jun 2, 2006 | 07:45 PM
rick lambert's Avatar
rick lambert
Blah, I say try it and let us know! I have to wonder the same thing as the Kid ! I once installed dual points in an earlier Ford (JC Whitney) and guys were confused, but it worked...so, if you've got a few extra bucks, and wanna have some fun, let us know!..
Old Jun 2, 2006 | 07:59 PM
Ramanstud's Avatar
Ramanstud
everybody likes to pick on the airfoil, but I wonder if it doesn't help part and full throttle EFFICIENCY, rather than an actual increase in "HP."
Meaning at WOT it may not create a repeatable difference, but similar to using smooth air ducts to reduce turbulence I'm curious if it doesn't give you a slight boost in economey via an increase in part-throttle HP?
Hard to measure part-throttle gains though. I never had an idle problem with mine on a 383 and a stock TB.
Old Jun 3, 2006 | 01:51 AM
Ruff Rider's Avatar
Ruff Rider
Got one on my 95 Lt1 A4, All I know is that it aint causing any problems.....I beat a newer C5 today WOT.............
Old Jun 3, 2006 | 07:18 AM
69mako's Avatar
69mako
Instal the "Tornado" and watch your MPG go through the roof
Old Jun 3, 2006 | 08:32 AM
mudslide's Avatar
mudslide
But I do wonder what bogus said about the IAC . I see some of them have a hole on the bottom to let air in to the IAC. Nothing but rain in ct. it sucks, so I have alot of time to think of things like thisPS my computer is so slow I didnt see Aardwolfs pic,which shows the hole for the IAC, now I wonder how it screws up the IAC
Old Jun 3, 2006 | 12:57 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default i got one soon as I got the vette
I bought it like many do, soon as I got my vette not knowing any better or worst....I would say, if you got a few extra bucks and don't mind it....it can't hurt. I have had mine on since 99. No problems with anything which includes, the IAC or TPS. I threw no codes and only difference I noticed was that at WOT or 3/4 throttle the engine seems to whistle a little different. At the TB of course, sounds kinda cool. I have seen and read so many things on it. Only logical conclusion I have come to is DON'T PAY THE $40 OR $50 Bucks brand new....You can find these things everywhere. On this site, other sites, that auction site, etc etc. I got one for $10bucks, the guy said it made a good paperweight but he had a few.
Save the wave
Later
Jeff
Old Jun 3, 2006 | 01:15 PM
jimmers's Avatar
jimmers
Ive seen that so many times on tv.
Old Jun 3, 2006 | 01:22 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
You shoulda heard a SoCal radio "auto guy" touting this product to the sky a few years back! It was funny, to say the least.
As to the airfoil, I dunno. I don't think it hurts anything, really.
Old Jun 3, 2006 | 02:57 PM
rick lambert
I think Mud otta put em both on..how about it Mud? buy you a drink if you do.
Old Jun 3, 2006 | 04:45 PM
mudslide's Avatar
mudslide
Make it a jug and Im in, smokin the tires all the way to ricks house for cocktails PS where the heck would the tornado go, wooo no wise cracks. OK of to my dads 79th birthday party he dosnt drink and I do so who do you think is going to have more fun
Old Jun 3, 2006 | 04:52 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Cut the air filter lid completely away except for the outer rim and install a K&N. That's all you need!
Old Jun 3, 2006 | 05:04 PM
Ruff Rider's Avatar
Ruff Rider
[QUOTE=BADDUCK]Cut the air filter lid completely away except for the outer rim and install a K&N. That's all you need![/QUOTE
What about a Vortex Rammer ???
To This cant be good
Old Jun 4, 2006 | 04:33 AM
jan-erik's Avatar
jan-erik
Hi.
I have an 85 and did not know about the discussions about the airfoil. I did not feel any change. The air do flow easier through the throttlebody. I believe in TPIS and other measurements, but what everybody seems to forget is that the airfoil only works with the 11hp gain if it is the throttlebody that limits the airflow. If you have any other obstruction in the chain of airflow from the air filter through the MAF , plenum intake and heads then it is that that limits the max airflow. The airfoil will not make things worse. If the idle air opening in the airfoil is little (if that is your concern) then open it up a bit more. TPIS has issued a flowchart to see the different influences in the intake chain. If you see at the airfoil measurement then you see that the airfoilmeasurement is done with a fully modified engine which means that the throttlebody will restrict the airflow.
To make the airflow better or easier through different parts never has been wrong.
Another case is to spend 40$ on this item on a stock engine. The throttlebody is enough for 300+ hp. I know that there are different views on this.
So my conlusion is that the airfoil cannot hurt the performance at all. Then I am speaking of the airfoils that you fix with a bolt on the throttlebody not the ones that you just put in to the hose just before the throttlebody opening.
Comments appreciated
Jan-Erik
Old Jun 4, 2006 | 08:09 AM
mudslide's Avatar
mudslide
I was thinking about buying a k&n filter but do you have to cut out the filter box? For the first time in my life Im trying to keep a car stock( Its killing me not to hot rod this thing ) or at least be able to put it back to stock without any permenent mods
Old Jun 4, 2006 | 09:02 AM
RRT vette's Avatar
RRT vette
Hey mudslide, I have the air foil that came off my 86E. You can have it FREE. Let me know. I'm will be gone for a few days.
