Broken rocker stud??????????????
Old Jun 2, 2006 | 08:41 PM
JTHVETTE's Avatar
JTHVETTE
Default Broken rocker stud??????????????
My wife was driving our '96 coupe Wednesday morning when it started to skip. When I got to check it that evening, I found that #5 intake rocker arm stud broke just below the roller rocker nut and lock screw.
I first thought that I might have installed the wrong push rods, when I built the engine. I got all my part numbers up and called Comp Cams to make sure every part in the valve train was correct. They said everything sounded good to them. I physically checked the pushrod and rocker arm part number this afternoon to make sure they were correct. I found all items to be correct.
What could cause the stud to break off? Fatigue? Do I need to replace all of the rocker studs?
Please Help,
JTHVETTE
Old Jun 3, 2006 | 12:13 AM
Ttime's Avatar
Ttime
It sounds like a freak incident. Personally, I would replace the studs out of fear but that's me. If anything, it's cheap insurance.
Do all of the other studs look OK?
Old Jun 3, 2006 | 08:06 AM
JTHVETTE's Avatar
JTHVETTE
All the studs appear to be fine. I am going to replace all of them to make me feel better.
JTHVETTE
Old Jun 3, 2006 | 09:03 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'd definitely replace them all. Are these stock studs? A set of ARPs will run under $40 so don't waste money putting stock ones back in. If you have roller rockers, go with the 1.75" length.
To Broken rocker stud??????????????
