runs fine, but then.........
quick recent background of repairs/replacements: fuel pump, f press reg, 1 injector,all injector/fuel rail o-rings, plugs, cap, rotor, wires,k&n filter, tb bypass,fuel filter(twice),remove frisbee, lowered, vac lines, idle air control, maf, open air box, starter,Valv durablend, the latest being the injector and the press reg.
after dealing w/ numerous performance issues, the car is running great at this time. Strong out of the hole, pulls strong throught the rpm range.
after a few days, I was getting on my favorite freeway onramp, a line of cars behind as usual trying to keep up, now it's time to stand on it! much to my supprise, and the guy standing on it behind me, this thing practicaly throws me through the windshild. now the guy behind thinks i'm messing with him and issues me the bird. a quick shift to n (auto) it lights back off, shift to 2 stand on it again, same thing, feels like i'm towing a parachute underwater.
if i take off and drive like there's a cop behind me there's no noticeable problems. but try and stand on it the same bogging down. lift off the throttle it stumbles then returns to idle, stay in it and it dies. it will light back off. if i turn it off & go in a store, come back & try to start it, lites off for a second & dies. and that's all she wrote until it decides that it has finished it's nap. then it starts and runs as previously described. this behavior gets kind of embarrasing. makes me think about yanking this computer controled motor and dropping in an old rat motor (haha).
any ideas would be great. Thanks
I asked Rich at Cruzin Performance for advice and he suggested I either purchase aftermarket injectors or get used Lucas style injectors from Corvette years 86 - 88 as these were very good and reliable injectors. I found a used set of injectors from a forum member from an 88 model (approx 30,000 miles) and I paid $80. Rich inspected the set for me and this cost another $30. He found they were a perfect matched set and did not need cleaning. I had heard negative feedback from aftermarked injectors and were afraid to try them. If you are pulling the runners to change out the injectors, this is not necessary. Send me an email to samlam@charter.net and I will send you info on how to do this....if you are interested.
Running your car with shorted injectors can damage the ECM as the shorted injectors are drawing higher currents through the injector drivers. Owing a Corvette is a continual challenge.....but it is fun!!!
http://www.theinjectorperfector.net/
