timing trouble on 91 L98
Old Jun 3, 2006 | 03:56 PM
revrun72's Avatar
revrun72
3rd Gear
Default timing trouble on 91 L98
I have a 91 L98 instaled in my 1972 vette. It pulses from 800Mv to 0 Mv on the OS sensor. The injectors are shutting off and on causing a surge and I believe causing the OS sensor reading. I have replaced ALL sensors TWICE and replaced the ECM and the chip. The problem still remains.
I had a Bullseye piggyback computer instaled to hopefully cure the problem. We live tuned the engine and it ran great for several hours and then began to do the dirty deed again. The tunning program showed all systems OK except the OS going 800Mv to 0Mv like every nanosecond. Something is causing the injectors to shut down and then back on.
Could the distributor be the problem? What controls the injectors? the ECM or the distributor? How do they interact?
HELP.......Glenn
Old Jun 3, 2006 | 04:20 PM
tequilaboy's Avatar
tequilaboy
Could be your O2 shorting to ground. I've never seen 0 mv.
Injectors are controlled by the ecm. The ecm gets rpm info, via the drp (distributor reference period ) from the dustributor.
Old Jun 3, 2006 | 08:18 PM
rodj's Avatar
rodj
Post this question over in C4 scan and tune also.
To timing trouble on 91 L98
