I bought a 1986 corvette bank repo with no original keys does anyone know how to by pass the vats system to start it I replaced the ignition key cly. but it does not have the chip in the key that only allowed me to get it out of gear
You have two options at this point - figure out the resistance the VATS module is looking for by buying all 15 resistors and trying each one individually until one works or buy a 30mhz bypass module from someone like www.bakerelectronix.com. I chose the latter. Installation was simple (power, ground, signal wire to ECU) and I put a small hidden switch in the ground wire so I can enable VATS if/when I choose.
A third option is to use a volume control **** and measure the resistance as you turn the ****. Set the **** to each of the 15 resistance values used by the VATS system. This saves you from buying all the resistors, but they are only a few $ from radio shack.
The reason you can't just ground or power the wire from the vats control module to the ECU is that the ECU needs to see a square wave signal, not a straight power or ground. That makes defeating VATS more difficult.
