Electrical Problems- 1985
Old Jun 4, 2006 | 11:38 PM
mikey whipreck's Avatar
mikey whipreck
Default Electrical Problems- 1985
--edit--- conclusion below---
This picture explains my problem I think.
What am I overlooking? Or how do I test for the problem?
1985 L98 Sport Seat Wiring.
Old Jun 5, 2006 | 09:03 AM
mikey whipreck
Can anyone help?
I know all of the motors and switches work (verified because they work on the other side. I can't figure out why the 12v power source only supplies power to the Seat Back motor and nothing else.
I have the electrical FSM's and I can't seem to find an answer in them. But I dont know how to test for the problem location either.
Old Jun 5, 2006 | 06:24 PM
mikey whipreck
40 views and no opinions?
any ideas at all?
Old Jun 5, 2006 | 06:46 PM
TimV SR's Avatar
TimV SR
My WAG for what its worth (nothing): You need three things for a complete circuit: 1. power 2. load 3. path. If you have power and a good load (motors), then the problem has to be in the path, ie wiring, switch, wire connectors, etc. If more than one motor is not working, I would suspect something common to them, such as a wire connector.
Old Jun 6, 2006 | 12:02 AM
jfb's Avatar
jfb
If you have the electrical diagnosis service manual, there is a procedure there to test every motor in the seat and all you have to do is follow the system diagnosis. If one motor runs, then your seat adjust switch is receiving 12v and ground. If you cannot get 12v ACROSS the motor wires on the other motors when their adjust switch is pressed, then the seat adjust switch must be defective or the plug- in connection from the seat switch to the motors aren't making contact and need to be inspected to see if the connectors are fully seated and there is no corrosion.
Old Jun 6, 2006 | 08:18 AM
mikey whipreck
First- thanks for the inputs ... this problem has me stuck
That makes me think the connection from the seat back motor to the rest of the electronics in the seat is bad...
The seat-back and pump motor both work in the Driver's side seat so I know those are good. All of the exposed switches work on the Driver's side (Bolster, Bladder and Seat-Back), so I know those are good. (I also tested those components- on both seats - outside of the car - per FSM - and they worked).
You both suggested this, and I am still learning the concepts here, but what you say makes a lot of sense. It sounds like that 2nd connecter is bad. Power goes to the first connector (the seat back motor runs), but nothing in the power line after that works. Since that seat back motor runs, it shouldn't be that connector right? That means it has to be the second connection (the larger boxy gray connector in the pic)?
Is my thinking right?
Thanks again.
Old Jun 6, 2006 | 12:25 PM
jfb's Avatar
jfb
Your thinking is correct, you just need to inspect the connection to find out why it is open circuit. Crimped connectors sometimes don't make connection.
Old Jun 17, 2006 | 07:03 PM
mikey whipreck
Thanks again to all who helped, I found (and fixed) the problem.
Someone was working on my sport seat functions before, and appearently bubba had the crimped connections out of the gray box, and had some stuff reversed.
So now power is going everywhere it's supposed to be
Except... this saga is still ongoing.
To Electrical Problems- 1985
