LT-4 into a LT-1 car
Old Jun 5, 2006 | 04:22 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default LT-4 into a LT-1 car
As some may know, I damaged my engine back in April. I was going to rebuild but now I have the opportunity to obtain a LT4 engine. I have a friend who is a local racer who can obtain the engine from GM at a very attractive price.
My car now is a 94 LT-1 car with a MN6. So here is the big question:
I know the engine will fit physically but what about the computer OBD system etc... Can I use this motor without having to reinvent the wheel so to speak?? I believe the LT4 car is OBDII and has a couple of extra 02 sensors...
Old Jun 5, 2006 | 04:46 PM
C4RACER's Avatar
C4RACER
LT4 motor will run from a OBD-1 harness and sensor set-up pefectly fine. You may want to retune it a little to take advantage of the increased airflow and power. But no issues plopping that LT4 on there and running it off the OBD-1 ECM and existing sensor connections. I think the only thing added with ODB-II was a second O2 sensor, which is not part of the engine itself anyway. The engine sensors are all the same.
Old Jun 5, 2006 | 05:31 PM
Zix's Avatar
Zix
The OBDII system added a few extra sensors and toubleshooting codes/diagnostics. You can certainly run an LT4 motor on an OBDI computer though...lots of people have done it. Other than the rear O2 sensors, the OBDII system also has a crank sensor to help determine misfire conditions as well.
Old Jun 5, 2006 | 05:37 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
You can just eliminate the crank sensor and it's pretty much a plug and play from there. If you remove the crank sensor completely, a 3/4" core plug will fill the hole.
Old Jun 5, 2006 | 05:38 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
What dealer is still keeping one hidden from Stock. I havent been able to find an LT4 engine in quite sometime.
Old Jun 5, 2006 | 05:43 PM
Corvette Kid
You don't think he's gonna tell you, do you?
Old Jun 5, 2006 | 05:45 PM
steve40th's Avatar
steve40th
I did a warranty search using a VIN from a friends car to get one, and they werent available. Then again, maybe someone wasnt looking.
And I emailed Chris May a while back, and it was unavailable.
But your right, if he has one, why would he tell us.
Old Jun 5, 2006 | 05:46 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Shhhhh!!!!
I am not telling until mine rolls into the shop... It is a long block not a production engine. This is what I have been told by my buddy who is buying it. I will wait and see what is unloaded from the truck. Now I just need a LT-4 intake manifold. That is funny part, dont you think??
Old Jun 5, 2006 | 05:49 PM
steve40th's Avatar
steve40th
Better get on E Bay and get your LT4 intake, as they are going for stupid prices now. Or wait till Edlebrock actually makes theres. Or, for 500 bucks, EPORTworks (LLoyd Elliot) will port/weld etcetc to make the LT1 work on the LT4 heads.
Old Jun 5, 2006 | 05:54 PM
Corvette Kid
It's insane what they're going for. Had I known, I'd have bought out Summit when they had them new for $200 and maybe I could retire! I'll bet if you've got any good local performance fabricators you could have an LT1 intake modified to work for much less than five bills.
Old Jun 5, 2006 | 06:10 PM
VenkmanP's Avatar
VenkmanP
You'd end up with a much better engine for less money by rebuilding.
Old Jun 5, 2006 | 06:12 PM
steve40th's Avatar
steve40th
I think LLoyd ports and polishes it too, for 58 mm etc. But yes, it cant be all that much to do, imo
Old Jun 5, 2006 | 10:24 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Perhaps
That may be true but I discovered the first replacement engine (Installed by the previous owner) was from a dang camaro or maybe an Impala.... Two bolt main. To me that changed everything. I was going shopping for another block or to machine the exsisting block and that was adding up. The LT4 was cheaper than a LT1 and comparable to a rebuild... go figure!? Plus, I will be back behind the wheel of the vette before the summer is over.
Update: located a LT4 intake for $600.00. On my way to buy it tomorrow.
Old Jun 5, 2006 | 11:35 PM
DieL's Avatar
DieL
2 bolt mains. Lucky you ! build a budget 383 and splay that 2 bolt block.
To LT-4 into a LT-1 car
