Light: Service Engine Soon
I am new to a 95 Black Vette with LT1 P engine. Last night while crusing the DIC amber warning light "Service Engine (logo) Soon came on. It stayed on until I reurned home. The Vette rested a few minutes and I drove again without the light appearing. This morning I drove to the Atlanta airport via 85, about 50 miles, and it did not come on.
Advice please. What are the common trigger events for this light to appear? I do weekly commutes for the next two weeks, to and from airport, total 100 for the round trip and then the two weekends. Then, I can get it to a shop (Christian Brothers - Dacula) that I have high very high trust in from work with a BMW, a Cambry, and a Previa, and another Cambry. I do not know of their Vette experience; however.
The temp gauage seems a bit high, about 200. But from past experience that is not "high". Other gauages seem normal. All else seems fine.
I could be incorrect, based on my Vette inexperience, on my gauge conclusions. They will take some getting used to. They do not naturally run as I would expect the them to run.
Thanks in advance.
Looks like this
[01|02|03|04|05|06|07|08]
[09|10|11|12|13|14|15|16]
With a piece of wire or paper clip short pin 4 to pin 12
Turn the ignition to run (don't start the engine).
Look at the speedometer LCD and write down what you see for the following modules. You should see C12 which indicates the diag. is running then the error codes for the different modules.
1.0 CCM (Central Control module)
4.0 PCM/ECM (Powertrain computer)
9.0 ABS/TCS (Anti lock brakes traction control)
A.0 Derm (Air bags)
