Check Engine light but C12 code??
Old Jun 5, 2006 | 09:44 PM
barry96's Avatar
barry96
Default Check Engine light but C12 code??
1996, 50K miles.
After reading about the DTC codes today, I got home and shorted the OBD connector pins 4&12 and all I got was a C12 code - nothing stored - but my check engine light is still on even after clearing (though there was nothing to clear!).
What's next?
Other info - the PKE light is always on as that system sent bad on my last year and I disabled it. I'm hoping to replace the PKE computer soon but its not on my priority list. Car is running fine.
Old Jun 6, 2006 | 12:36 AM
Steel Breeze's Avatar
Steel Breeze
Originally Posted by barry96
1996, 50K miles.
What's next?
My 88 is doing the same thing. even when cleared, but my guess is, at least on mine, after I clear it, I put the battery cable back on, and it makes contact right at first, then doesn't untill I get the thing screwed in. Think I will just loosen it a little, clear it, then screw it in. I hope it works, Maybe you are experiencing the same thing. Just a thought... Think I'll watch this post if ya don't mind?
Old Jun 6, 2006 | 02:08 AM
bogus's Avatar
bogus
take it to the local autozone and have them scan the computer for codes... their machine should also clear them.
Old Jun 6, 2006 | 04:17 AM
steve1ph2's Avatar
steve1ph2
DTC 12, ON-BOARD DIAGNOSTICS OPERATIONAL, NO CODES
DTC 12 indicates on-board diagnostic system is operational and no codes are present
Old Jun 6, 2006 | 08:35 AM
barry96's Avatar
barry96
bogus - Is the OBD2 reader and it's reset ability is better than the built in diagnostics run from the dash buttons? It doesn't seem like the control module would fail and set the light while still work correctly displaying the codes on the speedometer in diagnostic mode. Is it possible that there is some short that turns this light on?
Is there a separate module that controls the display of the diag lights? I guess it's back to the manuals but I don't have much spare time for the next couple days. Work just gets too limiting sometimes<g>.
Old Jun 6, 2006 | 09:54 AM
runner140*'s Avatar
runner140*
Barry, a DTC 12 shows that the system is working. Disconnect the negitive battery cable for 30 seconds then reconnect. That should put out the SES light.
Old Jun 6, 2006 | 10:06 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Your 96 is OBDII. The 94 and 95's had the OBDII connector but were still OBD1.
To read the PCM DTC codes on a 96 you need a OBDII reader.
If the Service Engine Soon light is on, that does indicate the PCM has detected a problem.
Old Jun 11, 2006 | 06:54 PM
USCG's Avatar
USCG
That's what I thought until corrected by SkateboardDave. Do a search of him or me within the past month or so and you'll find a post you'll want to print and save.
Old Jun 11, 2006 | 07:04 PM
RRT vette's Avatar
RRT vette
they should be able to pull the code for free. They have the scanner for 96 and up... OBDII
Old Jun 12, 2006 | 12:05 PM
Hooked on Vettes
I read one of your old posts where you shorted pin 12 to pin 4 and looked at the speedometer display for any DTC's.
From your response, Module 4 (PCM/ECM) error codes were not displayed. All of the other Modules
CCM, ABS and Derm were displayed when you shorted 12 to 4.
In my response to this post I mentioned you can't read PCM codes on a 96 without a code reader. (You could read the PCM code if you had the proper scanning software).
I'm not sure why GM didn't allow you to check PCM codes by shorting pin 12 to 4. Someone did mention it could be because the Speedometer display doesn't have the capability of displaying enough digits.
Old Jun 13, 2006 | 12:23 AM
barry96's Avatar
barry96
Default Update
I was going get into this more this past weekend but the darn thing just turned itself off! So I'm not going to try and track down this ghost. The only thing I can think of is that I tightened the gas cap (after reading some other posts). But shouldn't something have been recorded in the OBD system is the light ever goes on?
Oh well.
Now I have a more serious problem - the water pump seems to be lightly spraying antifreeze around. This is not good.
Old Jun 13, 2006 | 12:38 AM
bogus's Avatar
bogus
Barry - OBDII is capable of self resolution. I would still find out the source of the code. It will be stored.
To Check Engine light but C12 code??
