ZF parts source-Anyone know?
Old Jun 6, 2006 | 09:39 AM
cv67's Avatar
cv67
St. Jude Donor '05
Default ZF parts source-Anyone know?
Would like to get the synchros (90) replaced eventually....Im well aware that ZF Doc does this but dont have huge $$ to do it. There has to be a source for these parts, maybe the collective thoughts of C4 Gen can rustle up some info. Its just a tranny, cant be all that bad, right?
I know I could buy a replacement trans, but I like the gear whine from my black tagger.
Old Jun 6, 2006 | 09:51 AM
DDSLT5's Avatar
DDSLT5
ZF will only sell the parts in huge quantities, so it is expensive. How about contacting Kurt White once he is back from his honeymoon?
Old Jun 6, 2006 | 10:44 AM
Zix's Avatar
Zix
I was at Bills place just before I flew up to Boston to ask about getting some rebuilt clutch hydraulic parts and in passing he mentioned that ZF syncors are getting very hard to find again. He talked to ZF about it and they said they are going to do another run of them, have to completely re-tool an assembly line for it they are not going to be cheap... This happened a couple years ago as well!
bogus's Avatar
bogus
remember - the ZR1 tranny has a different input shaft over the LT1/L98 ZFs.
Contact zf doc... I think his prices have come down since ZF removed the ban on rebuilds.
Also, I think Richmond is a parts supplier...
however, I must warn you, are you SURE you want to tear into one of these boxes? They scare me... I read the article in Corvette Fever a couple years back... heating shafts, freezing gears, little springs and ball detent thingys, special gigs... no thanks.
Old Jun 6, 2006 | 12:25 PM
dizwiz24's Avatar
dizwiz24
Quick suggestion.
If you are running the castrol bmw stuff, try switching back to the proper GM pn factory fill.
This cured my syncho problems (grinded gears on upshifts, esp under hard acceleration)
Old Jun 6, 2006 | 01:37 PM
bogus's Avatar
bogus
it might help, but his ZF has 150k miles or so on it... they don't last forever...
Old Jun 6, 2006 | 04:55 PM
Cdn Z06 Mike's Avatar
Cdn Z06 Mike
Rockland standard gear makes the stuff and supplies but they are not cheap!! You would be better off buying a brand new one!
http://www.rsgear.com/
Old Jun 6, 2006 | 05:18 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'd heard Rockland, too.
Old Jun 6, 2006 | 05:19 PM
bogus's Avatar
bogus
Rockland - that's it! Got the name mixed up.
Old Jun 6, 2006 | 05:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm sure you know what you're up against so if you're willing to do it, go for it. I rebuilt a ZF trans. in a mid '90s Ford Super Duty truck a few years back and had none of the many special tools called out for in the manual. Yeah it was a PITA but nothing insurmountable. It's just a transmission. It was either a 5 or 6 speed, I really can't remember now but looked very similar in design to any other ZF I've seen. I've got a Vette one here at the house that I'm going to tear into when I get time. It's stuck in reverse I believe it's owner said. He's already replaced it so I'm just going to fix it so he can sell it.
Old Jun 6, 2006 | 06:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
Thanks for the info (rsgear), Ill look into it. Someone I know may tear into it if can get parts.....I wouldnt personally tackle it myself, did one M-22 years ago that turned out well, the other one I wound up taking to a tranny shop in a 5 gallon bucket.
Trans is still in good shape, but Im thinking this winter would be a good time to yank it and freshen it up, Im pretty picky about how they work.
Im sure there is plenty to know about the ZF trans, but its just parts in a case-If it can be assembled, it can be disassembled and back without financing your first born-I hope!
Old Jun 6, 2006 | 06:24 PM
Zix's Avatar
Zix
The ZF-S50 or S60 (I forget which one is the common truck tranny) has completely different internals) than the ZF-S40
Old Jun 6, 2006 | 06:28 PM
Corvette Kid
I realize it's not the same tranny. But it's still got the same, over-complicated PITA German engineering. I'm not one of those who's ever been impressed with German engineering from a mechanics point of view. Yes, some of it works well but they seem to delight in going out of their way to find the most difficult way to accomplish anything. No wonder we kicked their asses twice.
Old Jun 7, 2006 | 07:26 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
Sometimes I think they do engineering for engineering's sake...
"lets see how complicated we can make this?" I think they need some good cost control accountants.
Old Jun 7, 2006 | 10:42 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Did you do a special jig before opening up the case?
Old Jun 7, 2006 | 12:23 PM
bogus's Avatar
bogus
the ZF6 in the vette requires one to support the gear shafts.
Old Jun 7, 2006 | 05:17 PM
cv67's Avatar
cv67
St. Jude Donor '05
A basic going through by ZFDoc (talked to him this morning) starts at $2400, this is for new synchros and a rebuild kit. New gears, +$700 for each one, etc etc. Very helpful guy, like his mod to the stock shifter that retains the reverse lockout feature.
To ZF parts source-Anyone know?
Old Jun 7, 2006 | 05:29 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Wasn't that the one known as "the rock crusher"? Or do I have it confused with another trans.
Old Jun 7, 2006 | 05:50 PM
Corvette Kid
So did the one I worked on. But I managed w/o it.
Old Jun 7, 2006 | 06:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
