help??
Old Jun 7, 2006 | 11:47 PM
crumby2's Avatar
crumby2
Default help??
need help 1989 auto. idles a little rough but with tranny in drive the engine will miss or shutter at 45 mph then in OD at 68mph it will do the same any suggestion would be appreciated.( new plugs wires cap )
Old Jun 8, 2006 | 12:53 AM
Hooked on Vettes's Avatar
Hooked on Vettes
If your car has the original Multec fuel injectors (gray body color) unplug the injector connector and measure with an ohm meter the resistance across the coil windings.
Should be around 16 ohms. Do this when the engine is cold and with the engine hot. The injector coils on the Multec injectors used in 89 are cooled by the gasoline. Over time the some of the additives would eat away the insulation of the coils.
Old Jun 8, 2006 | 01:29 AM
crumby2's Avatar
crumby2
bought the car in 2004 and was told it had new injectors all thisstarted after i had a new intake manifold gasket just instaled plus wires cap and plugs thanks crumby
Old Jun 8, 2006 | 01:32 AM
Jack_leg's Avatar
Jack_leg
Default Have you done a basic tune up.
If you haven’t done a basic tune up, (plugs, wires, cap, and rotor) then do that before you start playing around. Too many people look for problems when it’s just maintenance. How long ago, how many miles since you done this.
Old Jun 8, 2006 | 01:49 AM
RRT vette's Avatar
RRT vette
A fuel pressure guage, FSM, a timing light, multimeter, and good set of tools, can give you a lot of info on a C4. There are a number of things it could be. Clogged fuel filter, failing fuel pump, faulty injector(s), dirty IAC/TB, out of adjusted TPS, spark plugs wires not going to the right cylinder, vacuum leaks, faulty O2 sensor, dirty air filter, clogged PVC, MAF error, bad ECM, ect.
Is the Service Engine Soon light on?
Have you checked fuel pressure?
Does it idle rough when the engine is cold, hot, or both?
Are the spark plug wires routed correctly and to the right cylinder?
Are you sure you have spark at each cylinder?
Give us a little more info and it souldn't be hard to find the problem.
Old Jun 8, 2006 | 02:02 AM
Jack_leg's Avatar
Jack_leg
Default Yeah
I concur.
If you do these things first you can save time and Money.
Old Jun 8, 2006 | 08:32 AM
Pete K's Avatar
Pete K
Could it be a torque converter beginning to fail? Try disconnecting the plug on the pass side of the trans and take a test ride. Had something similar happen on a friends 84. It was the converter, in his case. Worth a look. Quick and easy to do.
To help??
