Should I replace my T.V. cable?
Old Aug 28, 2001 | 12:38 AM
Cruz 86's Avatar
Cruz 86
Default Should I replace my T.V. cable?
I was wondering if these things stretch and would it even matter if they did. I like the way my tranny shifts when I set the adjustment a little tighter than specs. The only problem with this setting is the throttle body butterflies aren't able to open all the way up. Anyone understand what I'm saying? I thought maybe the cable is stretched or something. The trans itself operates great at this setting. What do you guys think?
Old Aug 28, 2001 | 04:17 AM
NoWorries's Avatar
NoWorries
Default Re: Should I replace my T.V. cable? (Cruz 86)
Depending on where you live, Cable might not be your best option...you might get better reception and even a better deal by going with a Satellite provider.
I like Direct TV. :D
Old Aug 28, 2001 | 04:19 AM
NoWorries's Avatar
NoWorries
My TV Cable broke off when I pulled the transmission, it was like $30 to replace and a pretty difficult job.
They don't stretch, but will eventually break, because its touching the block right next to the distributor and is very close to the transmission. I would leave it alone, mine was probably fine for another 50,000 miles had I not tweaked it.
Your hood release cables on the other hand should be replaced at around 10 years old. They are known to break and are easy enough to replace. $32
To Should I replace my T.V. cable?
