ZF Transmission noise
Old Aug 28, 2001 | 02:40 AM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default ZF Transmission noise
Okay heres the deal i can drive the car all day and as long as it doesn't get up around 200+ deg everything is fine, once it goes past that when the fans kick on i get a clanking noise that is coming from underneith the car, sounds like from the bell housing or something on the tranny, anyone else get this noise? I am driving down to BG on thursday and don't want the tranny to crap out on me, since the clutch was replaced 11,000 miles ago i don't think it was that, i have heard it before but i maybe just getting parinoid because of the trip any suggestions?
Old Aug 28, 2001 | 06:59 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default Re: ZF Transmission noise (91_Corvette)
You may need to have it put up in the air and check it out closer to see exactly where it is coming from... :yesnod: :cheers: :seeya
Old Aug 28, 2001 | 11:34 AM
No Ordinary 91
Default Re: ZF Transmission noise (Yello95)
the only problem is it only does it sometimes and its usually when i am away from my house
Old Aug 28, 2001 | 03:52 PM
No Ordinary 91
no one else has ever had anything like this?
Old Aug 28, 2001 | 06:32 PM
COMPVET's Avatar
COMPVET
91_corvette
Your problem is definately the dual mass flywheel. There is no solution other than replace it. A lot of people have gone with a single mass (standard) flywheel in an attempt to save a few bucks, but most end up less than impressed with the increase in gear noise. This is a common problem that occures with these cars and it's not a cheap part to replace.
Post again if you require further info.
Pete.
Old Aug 29, 2001 | 03:25 AM
No Ordinary 91
Default Re: ZF Transmission noise (COMPVET)
well, is it something that is going to cause problems or wear on the tranny? i have just recently paid $1400 to have the clutch replaced, and would really prefer to wait until it comes time to replace the clutch again to re-do the flywheel and everything all at once
To ZF Transmission noise
