Failed Emissions Pressure Test/wont Idle
Old Jun 9, 2006 | 10:51 AM
1988 BlknBlk's Avatar
1988 BlknBlk
Default Failed Emissions Pressure Test/wont Idle
Ok I may need to call my therapist! I cant drive my C-4! It failed the pressure test...they said I have slight leak somewhere in the fuel vapor system. To be exact they said it holds then bleeds off very slowly. Any ideas on what might be a common fix for this problem?
Secondly...after going the emissions the vette was idling at 400as opposed to the usual 600-700...then once i got it home after turning the car off it didnt want to idle at all! If depress accelerator car stays on and sounds as strong as it usually does, but once I let go it dies! I have started checking vaccuums but nothing yet......
Please help me! I need my vette! Im lost without it!
Old Jun 9, 2006 | 12:09 PM
1988 BlknBlk
Default anyone????
anyone have any ideas?
Old Jun 9, 2006 | 12:48 PM
TM-Z06's Avatar
TM-Z06
Have you changed the fuel cap lately?
Old Jun 9, 2006 | 01:06 PM
1988 BlknBlk
No i havent changed the fuel cap...but I do know they do separate test on the fuel cap...to pressure test they screw their own cap with a pressure line attached and then pump 2 lbs of pressure into the tank...then they crimp the fuel return line up front by the canister....
Old Jun 9, 2006 | 03:11 PM
Perfusion's Avatar
Perfusion
What the hell state is THIS!?!?! I thought CA was the worst-of-the-worst, and we don't even have to do that test!
Old Jun 9, 2006 | 03:31 PM
1988 BlknBlk
Default Phoenix-Arizona
Im here in PHOENIX-ARIZONA
Jeesh...I agree that I thought the test was somewhat ridiculous !
My car is passing the actual emissions tests with flying colors....just didnt pass that blasted pressure test...which qualifies as an equipment failure!
Old Jun 9, 2006 | 05:10 PM
1988 BlknBlk
Default Help???
Anyone?
Old Jun 9, 2006 | 11:19 PM
joalyons's Avatar
joalyons
Originally Posted by 1988 BlknBlk
Anyone?
I think if you fail twice they send you to a special station where they can give you some answers. When I lived in Phx a friend failed for the same thing on a pickup truck and found out he had a pin hole in the fuel filler line. Bottom line it was a good thing, I would check or replace all the soft lines from the tank and then back to the tank.
Old Jun 9, 2006 | 11:44 PM
mikesb's Avatar
mikesb
My 87 failed the pressure test once also, just in front of the drivers side rear tire is a small piece of hose connecting two metal tubes that are part of the vent system. this hose was where my problem was. I also found the hoses going to the vapor cannister were in poor shape. check them close to.
Old Jun 13, 2006 | 01:27 AM
Insane1's Avatar
Insane1
Yet!
It is coming though. Within the next year or two. It's about a $3000 upgrade to the smog system. And they also have a camera port that they might start videoing the tests as they are being done. The techs that maintain the machines just got done putting an anti-tamper system in the units so that if any unauthorized people open up the machine it disables it and reports back to the DMV and needs to be reset by the tech. Seams smog technicians figured out a way to open up the back of the machine and get just about any car to pass.
Old Jun 13, 2006 | 11:11 AM
1988 BlknBlk
Default Thanks!
Great! Ill check that hose! Thanks alot!
Old Jun 13, 2006 | 12:45 PM
1988 BlknBlk
Default Any ideas on the idle?
I have checked the connectors on all the sensors (MAF-EGR-IAC) They all look good...I checked for fuel pressure at the fuel rail-fuel was there! I have checked every vacuum that I could see. Im at a loss here...
Thanks for all the help guys. You have been a big help already!
Old Jun 13, 2006 | 03:07 PM
1988 BlknBlk
Default Iac
Spoke to a Vette shop...they said to replace the IAC valve, possibly test the ohm on the TPS also?
Sound like a direction to take?
Old Jun 14, 2006 | 09:42 AM
1988 BlknBlk
Default I feel like Im not the brightest at times!
Well I tested the IAC..ohms were at a steady 55...TPS checked out also.....So there I was, very frustrated, I decided well all else has failed. Why not see if a small adjustment of that idle screw will make a difference? A litttle over if not a half of turn made all the difference! Car is running just like it did a week ago! What do you guys think...is that normal? Is it normal that a small adjustment of that nature could be necessary? I read in my manual that it's factory set, but it solved my problem...
Old Jun 14, 2006 | 03:22 PM
1988 BlknBlk
Default anyone
Old Jun 14, 2006 | 07:12 PM
1988 BlknBlk
Default Thank You Steel Breeze & Cfi-efi!
Both of these gentleman took time out of their busy days to help me in getting some solid answers to the idle issue. They are why forums like these are in existence, to help and share with others.
Thanks a bunch guys! I will use the information right away!
Old Jun 15, 2006 | 02:06 AM
goldeneye_vet's Avatar
goldeneye_vet
Your idle is controlled by the ECM. That screw you adjusted allows air through the TB blades to control your idle with the help of the IAC. By adjusting that screw you have thrown it out of adjustment and both the IAC and the TPS will need to be adjusted now. Get your trusty paper clip out and a volt meter to assist in the adjustments. The tech tips section has a few articles on how to do this if you don't have a FSM. Good luck!
To Failed Emissions Pressure Test/wont Idle
Old Jun 15, 2006 | 09:55 AM
RRT vette's Avatar
RRT vette
I agree, after turning the minimal idle screw, you will have to recheck the TPS again. I did a little search and have some info on this.
From the Tech tips:
https://www.corvetteforum.com/techti...D=55&TopicID=2
From Vader86 webpage:
http://temp.corvetteforum.net/c4/vader86/tpsiac.html
1988 BlknBlk
Default Thanks!
Yeah CFI-EFI...shared with me what I had done wrong. I pulled the TB last night and removed the IAC...needless to say the IAC valve was gummed and black! The throttle plates were veyr dirty also...didnt look good at all...
I will be replacing the IAC tonight and giving the TB a thorough cleaning! How does one adjust the TPS?
Old Jun 15, 2006 | 10:02 AM
RRT vette's Avatar
RRT vette
The TPS is adjusted by unscrewing the 2 torx bolts and adjusting the sensor up or down to get you at about .54v stock. This should be done after you adjust the minimal idle due to changing the throttle plate position and will throw the TPS voltage off. With the new IAC you should get a new gasket and the pintle tip should already be 1 1/8" from the IAC flange but check and make sure before install. If not push or pull with a wiggle until there.
