Throttle body IAC
Old Jun 9, 2006 | 03:41 PM
wro87's Avatar
wro87
Default Throttle body IAC
I am looking at not using the IAC when I replace my Throttle body for a bigger unit nor are we going to use the water lines. Does anybody know if I delete the IAC can my PCM be reprogrammed to acknowledge it. I have to have the PCM reprogrammed any way ( reworked heads, different cam, roller rockers, intake, and new headers and no AIR fittings or converters real duals ) and can this be done? Thanks wro87
Old Jun 9, 2006 | 09:11 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Why don't you want to use the IAC?
My FSM does not list any trouble codes for IAC, so you should be able to simply disconnect the harness without any issues (other than the obvious one of not having any control over the idle )
