Charging System Problem Help!!!
Old Jun 10, 2006 | 11:42 AM
ROCKY85's Avatar
ROCKY85
Default Charging System Problem Help!!!
Here's the problem on the 85, new alternator and battery. Still does not charge properly, anyone had a similar experience? If so what the fix.
ROCKY85
Old Jun 10, 2006 | 11:49 AM
aminnich's Avatar
aminnich
Clean all primary cable connections. At the battery, at the starter and at ground points.
Old Jun 10, 2006 | 12:19 PM
ROCKY85's Avatar
ROCKY85
Okay, where are the grounds located onthis car.
Rocky
Old Jun 10, 2006 | 12:56 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Have you checked the voltage output at the alternator and at the battery? With a car of that age you could likely be experiencing significant voltage drop due to aging wiring. Are the belt and tensioner in good shape so there is no slippage? You can't always hear this as belt squeal. Did you buy a quality alternator and have you had the new battery load tested? Even new batteries are defective sometimes.
Old Jun 10, 2006 | 01:47 PM
ROCKY85's Avatar
ROCKY85
Every thing has been checked, voltage from alternator correct, battery tested great, but no voltage from alternator to battery.
ROCKY 85
Old Jun 10, 2006 | 01:54 PM
Corvette Kid
ROCKY 85
Simple fix then, your main charging wire from the alternator is broken or otherwise defective. Run a new 10 ga. wire from the screw on post at the alternator to wherever it's connected to the positive battery voltage on your year of car. This should take care of it.
Old Jun 10, 2006 | 11:08 PM
scorp508's Avatar
scorp508
No no no no no! Don't run a solid wire, unless you don't want your insurance to cover you for a possible car fire in the future. There is a 12 GA fusable link in between the alternator and the battery. It could have blown out. Mine did this one. You'll have to take the battery out to find it. It is buried down behind it amongst a bunch of other wires. It'll be a black cylinder looking thing with red wire coming out of both ends of it.
Old Jun 10, 2006 | 11:26 PM
Corvette Kid
No doubt a good point. I sometimes forget how prevalent fusible links have become since I began working on cars at which time they were non-existent. The HD vehicles I work on for a living generally use 2 or 4 ga. wire for charging and so there are no fusible links there either.
Old Jun 11, 2006 | 06:04 AM
RRT vette's Avatar
RRT vette
there is a bundle of red wires behind the battery (fusable link). I would as scorp said, check there and make sure they are not loose and are good and tight.
To Charging System Problem Help!!!
